Results 1 to 6 of 6
Thread: Amplifier question
    Aug 2008
    Amplifier question
    Hi, new here but not new to in car audio systems, The thing is i bought a new amplifier a Kenwood KAC-8104D to hook it up to two pioneer subs 1200 watt max, 400 rms and 4 ohm rating, the thing i amp wanting to know is that i know when you wire two subs in parallel then the ohm will be hlfed giving two ohms, but what i don't know is that if i wire them parallel will is split the wattage?
    Thanks Chris
    Jun 2005
    chicago, Illinois
    Two separate loads wired in parallel to the source will be given equal amounts of voltage to each load. Also, the total current will equal the sum of the current ran through each load wired in parallel. And since you are using like impedances for each load, the individual current through each of the 2 loads will equal each other, therefore total current will be divided evenly by the number of loads that are wired in parallel to the source. And that can be calculated to show that each load is being given half of the power (wattage) of the total output in your instance. So essentially the answer is, Yes.
    You really weren't thinking you'd get an answer without a full explaination?
    Aug 2008
    No, i didnt expect an answer at all but that long one was good for me, now least i understand, thanks very much
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    max/peak wattage generally is a useless spec. true RMS output/power handling is the spec to look for.
    when you wire speakers in parallel, the speakers are still the same impedance but the amp will "see" an impedance load/value half of each speaker's rated impedance (in your case, the speakers remain 4-ohms, but the amp will see a 2-ohm load).
    normally; when you cut the impedance in half, you double the RMS output power of the amp... but that amp's specs state 300w@4Ω and 500w@2Ω. I'm guessing that they underrate the 2Ω RMS output to keep the THD spec under 1% (in other words, it can probably output 600w RMS@2Ω, but with alot of distortion).
    the answer to your question is yes... two subs wired in parallel will act as one single sub (with it's power handling specs doubled, essentially "split"ing the wattage), so each sub will receive between 250w-300w RMS max (depending on the input volume and how you set your gains).
    since your subs are rated @400w RMS each (800w RMS total) and your amp will be putting out 500w-600w RMS total, you should be good to go
    Aug 2008
    Thanks very much for the answer guys, been really helpful
    Constant Bitrate kibble's Avatar
    May 2008
    Check out this site, it's called Basic Car Audio Electronics. It's got loads of good info with diagrams and charts and all kinds of goodies on car audio electronics! There's a section for pretty much everything you'd have a question about.
    Kids, don't play with too many knives! -Crack Stuntman
  1. Wiring two dual-voice coil subs to one mono amp
    By venom889 in forum Car Audio
    Last Post: 12-27-2009, 06:35 PM
  2. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 09:03 AM
  3. Does this exist? Single din amplifier?
    By justintime in forum Car Audio
    Last Post: 05-02-2005, 06:17 PM
  4. Amplifier Enters Protection Mode When Volume Is Up
    By skeeter007 in forum Car Audio
    Last Post: 04-16-2005, 10:31 AM
  5. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 01:21 PM
