Results 1 to 10 of 14
Thread: My Amp grounds through the Rca's anyway to fix?
    Jun 2008
    This is a continue part from this thread:
    http://www.mp3car.com/vbulletin/car-...battery-2.html
    I found out that my amplifier grounds through the carputer via the Rca's, i found this out by pulling the ground from the amp, the light was still on and i could still play music, i then removed the Rca's and the amp went off.
    What can i do with this? i even tried to ground the amp with shorter cables + smaller lenght on them, the grounding points is good enough cause their factory made.
    Somehow the ground from the amp only want to go through the Rca's to the Carputer.
    Could it be i need some other Rca cables? should there be resistance in the Rca cable's?
    Jul 2006
    Is the point where your ground wire attached to the car clean (no paint)? It should be bare metal, don't just assume that the bolt is grounded through the threads.
    MSI K9N6GM
    1 gig RAM
    8" Lilliput
    Onstar GPS mod
    XM
    Visteon HDZ300
    Jun 2008
    Quote Originally Posted by barnyard View Post
    As i said it's a factory made grounding point, bare metal, i have 2 bolts in the trunk where the carputer which is made for grounding things.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Maybe the RCA outer shield is grounded to the main ground of the amplifier? It seems that alot of designs do this to reduce noise. As long as everything is running properly, I wouldnt worry about it. Might be a good idea to check that the main ground has lower resistance than the RCA ground so that the power goes through the main ground and not through the RCA.
    Jun 2008
    Quote Originally Posted by nobb View Post
    It's not normal excactly, there's a lot of popping and crackling and i also get a lot of alternator noise then the engine is running, i measured the Rca cables and there's absolutely no resistance whatsoever through them, so my question is, are there Rca cables that has built in resistance? i read something about 75ohm or something.
    FLAC WuNgUn's Avatar
    Sep 2007
    Usually, one end of the interconnect is grounded (drained) thru the amp...this is typical.
    PLEASE do NOT run the amp with the main ground disconnected...unless you want to fry things!
    Jun 2008
    Quote Originally Posted by WuNgUn View Post
    Don't think i'll fry anything with this little amp, it measures only 100*52*150mm and gives around 20w rms x 4, pretty mutch the same as a standalone HU does, it even has the same wire size as one.
    By the way, do you mean that it's supposed to carry ground through the Rca cables? and if so, will better cables remove the noise maybe?
    Jul 2008
    Jun 2008
    Quote Originally Posted by crusetech View Post
    Yes i already ordered one of those:
    http://www.bilradiospes.no/m/shop/?p...id=m436&vn=736
    But as i read this is only a bandaid solution.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    its no solution at all.. i have the same problem and that will NOT remove all of the noises. The real solution would be to find how to isolate the ground in the rca cables.
    Live mp3Car Facebook Chat
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. Unusual amp shut off problem....please help!
    By mike40370 in forum Car Audio
    Last Post: 12-05-2007, 05:13 PM
  3. why does my amp have 2 grounds?
    By brendan in forum Car Audio
    Last Post: 12-21-2006, 05:57 PM
  4. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
