Results 1 to 7 of 7
Thread: amplifier hookup
    Nov 2007
    amplifier hookup
    My current setup in non carpc. I am making the transition and I have 2 Amplifiers. 1 is dedicated for my subs, the other is a 4 channel for my interiors. On the back of my radio there is a front output which is what the interiors are hooked up to. I have 2 sets of RCA going to that amplifier, they are hooked up to the radio with 2 y jacks. The other output is labeled sub and that goes directly to the sub. Now without using 3 sets of Y jacks to utilize all 3 RCA's , how do you recommend hooking up the amplifiers?
    Aug 2008
    I would like to know this also.
    Elsewhere
    You have two options.
    You either use the 3 sets of Y cables or you put an equalizer in-line to convert simple stereo to 4+1.
    How about the Wiki?
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Simple.
    Since you say you're making the transition (I assume to a carputer), get a 4.1/5.1/7.1 sound card when building you carputer and wire the amplifiers accordingly.
    Unless you're staying with a headunit. Then you're stuck with Darques recommendation. If you are planning to keep the head unit, I say take the plunge and get rid of it. No sense getting in the pool if you plan to stay in the kiddy end...........
    C'mon in, the water's fine!
    cheers
    Leonardo Da Vinci
    Elsewhere
    I did forget about the headunit option.
    How about the Wiki?
    Nov 2007
    Quote Originally Posted by greatwhite View Post
    Simple.
    cheers
    lmfao, im stuck at work reading this and loving it. Thx i needed this. I will look into installing a sound card. Think i have one left over from a old build.
    Nov 2007
    Now that im brainstorming, I found a old crossover I had laying around. Gonna use that instead and see how it sounds.
  1. Wiring two dual-voice coil subs to one mono amp
    By venom889 in forum Car Audio
    Last Post: 12-27-2009, 07:35 PM
  2. Why is my amplifier grounding out on my computer?
    By Maheriano in forum Power Supplies
    Last Post: 08-31-2008, 05:20 PM
  3. specific amplifier problem question
    By audioguy3107 in forum Car Audio
    Last Post: 09-15-2007, 11:13 PM
  4. Replies: 15
    Last Post: 02-15-2006, 12:50 AM
  5. Looking for small amplifier
    By Suprapc in forum Car Audio
    Last Post: 10-05-2005, 06:27 AM
