Results 1 to 5 of 5
Thread: USB sound card behind USB hub?
    Jan 2008
    Southern Calif
    Are some of you running your USB sound card behind a hub or just feeding it directly to a usb port on pc?
    Sep 2007
    Raleigh, NC
    Im running mine off a hub with no problems.
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Running mine off the cheapest usb 2.0 hub I could find from dealextreme, no problem.
    Nov 2006
    Adelaide
    Mine was going through a hub, with GPS Module + Touch screen + Wifi. It struggled to play 24bit music, it'd pause and skip. I connected it straight to my M/Board and havent had a problem since.
    Jan 2008
    Southern Calif
    Well my Audigy 2NX usb sound card is behind a hub but almost everytime I start up my computer (full boot up) Windows has the little X mark on the lower right taskbar, and therefore I can't hear sound. It shows up on the device manager though, if I disable and enable it it then shows up fine and sound is heard.
  1. Usb sound card recommendation
    By HuseyinOzsut in forum Car Audio
    Last Post: 10-11-2008, 07:49 AM
  2. Replies: 8
    Last Post: 11-04-2006, 02:13 AM
  3. Powered Hub, Lots of USB Devices! Will this work?
    By adamharrisuk in forum General Hardware Discussion
    Last Post: 05-15-2006, 12:00 AM
  4. USB Sound Card doesn't power sometimes...
    By n0irsmurf in forum Newbie
    Last Post: 05-02-2006, 07:10 PM
  5. Ground loop with an external USB card?? Help! (LONG)
    By vettejock99 in forum Car Audio
    Last Post: 02-05-2006, 11:20 AM
