Results 1 to 8 of 8
Thread: Volvo V70 radio harness
    Newbie jongscx's Avatar
    Aug 2008
    Ok, I used a radio harness kit from my friendly neighborhood audio store... and it looks like some of the pins aren't being utilized.
    It has everything that I need, 12V+, ground, Speaker connections, etc... but I'd just really rather know what those other pins are for.
    It's a 1998 Volvo V70 using the stock CD player and NO factory amp. if anyone has any leads or info, I'd appreciate.
    Newbie NATISFYNEST's Avatar
    Aug 2008
    da nati
    what "pins" are you talking bout? you should have 2 white,green,grey,purple those are speaker wires you should have 1 red,yelowand black wire those you should know then you will have 1 ornage wire which is for auto dimming when you turn your interrior lights down if the radio supports the function it will dim also. then you should have 1 blue wire for power antenna/remote wire for your amplifier
    Aug 2008
    yeah, I have those, and those are basic. Power, stereo, dimming, amp control, etc. etc...
    but when looking at the volvo plug that the adapter plugs into, some of the wires on the volvo/car side do not have a mating pair on the adapter side. The radio works perfect right now, so obviously, all the functions that are required work. I wired the stereos front/back-Left/right all correctly (for my first, I'm kinda proud of that :-D)... but I was just curious as to the other stuff.
    Also, my lilliput has an automatic rear-view connection to the tranny that automatically switches the viewpoint to Rear Cam when I'm backing, and back to whatever when it's on everything else... Any idea where this connection is?
    Aug 2008
    da nati
    so what your sayin is your hookin up your lilliput and not all the wires are there to connect. like i said the radio may not support auto dimming and other features. if its a flip out monitor you will have some wires with no place to be wired to because they put safety features to keep you from watchin tv/dvds while drivin
    Aug 2008
    no, I mean that the volvo has some pins that the adapter does not address (the adapter does not have wires for them) and I want to know what those pins are for...
    Aug 2008
    da nati
    that i cant exactly answer sorry i can assure you that they are not important and they are nothing that you will miss either
    Aug 2008
    I certainly hope so... otherwise, I'll be pulling panels off needlessly for something that was already there.
    In any case, do you know of any detailed wiring diagrams I could get?
    Aug 2008
    da nati
    if you go to your local dealer they shoud print some out for you or you can buy a haynes manual
  1. Volvo v70 carputer
    By roedkaelk in forum Worklogs
    Last Post: 09-30-2011, 05:37 PM
  2. Delco Radio Swap for another Delco
    By novice in forum General Hardware Discussion
    Last Post: 05-31-2008, 08:10 PM
  3. 323is radio harness
    By bootscraper88 in forum Car Audio
    Last Post: 05-16-2008, 10:01 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  5. any suggestions on aftermarket harness for my radio
    By afterdigital in forum Car Audio
    Last Post: 03-08-2007, 05:16 PM
