Results 1 to 7 of 7
Thread: Home Audio Woofer in car
    Oct 2008
    i know its pretty ghetto, but im questionable on putting my 200 watt all in one amp/sub woofer in my car. its basically a box with an amp and woofer in one, it does need power. so my question is, is their anyway of doing this with out completely mutilating my trunk/woofer?
    i have a 10 disc changer in the trunk so there's at least something hot back there that i could potentially use to power it?
    Elsewhere
    Quote Originally Posted by BlackFlame View Post
    VERY ghetto.
    If you keep the sub in its enclosure and securely mount it in your trunk, you should be fine.
    Nope. You'd need an inverter.
    If you're willing to dig into the power requirements of the amp and see if it can accept DC power, you MAY be able to get a regulator to power it.
    But an inverter is the easy way to accomplish what you want.
    How about the Wiki?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    In the end, it's not worth it. Inverters introduce way too much noise into the electrical, it'll more than likely sound like crap. You may even start to hear engine noise/whine thru your stereo. How do I know, you might ask? I've done it.
    Maybe if you get a high dollar true sine inverter to run it, but then it'd just be cheaper to go to wal-mart and get a crappy amp, sub, and box. I would think that would be better than using a home-audio setup.
    Tidder
    Try RevFE
    Oct 2008
    well it seems your right, it seems like a waste of time.. i found this woofer at walmart. http://www.walmart.com/catalog/produ...uct_id=6014618 it seems like a bargain. now i need to find a guide on how to install it...
    Oct 2008
    Quote Originally Posted by Tidder View Post
    well said.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    and no the power for the cd stacker would not be enough, you would need to run a new fat power wire from the battery to the amp/inverter.
    Oct 2008
    Actually, that speaker setup is decent. You're not gonna get real deep lows out of it, unless you take the speaker out of that box, and put it into something a bit bigger, but the amp for it does power it decently.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
  3. Installing car PC in 1996 Honda Civic
    By PredatorCoder in forum Newbie
    Last Post: 08-18-2005, 08:58 AM
