Results 1 to 8 of 8
Thread: Intercepring audio from Mercedes CD Changer
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    hey all
    I just tryed Car2PC as a way to connect my PC to Mercedes C280 stock radio, unfortunatly it requires me to disconnect CD changer and I wanna keep it.. id rather do some sort of a switch for oudio to select between either CD auduio and PC...
    the CD changer has 6-pin molex connector, so I assume taht one (or 2 ) wires the sending plain audio signal to the the headunit. (Am i right?) If so I wanna put the Mp3Car usb audio source switch on thta wires to select my audio source... [HL]the problem is that i dont know which pin is responsible for oudio signals[/HL].. so maybe some one knows that or maybe you have access to the drawing files.... i would really apreciate the help!
    THanks!
    Oct 2008
    Did you solve the problem?
    What is your head unit? Can you post a photo of the head unit...
    Jun 2007
    New York
    yep i did solve the probelem
    on the back of the unit on the CD connector thee is one cox wire that gets separated into 3 wires... = thicker black, red and yellow
    Black - is you ground (not yet sure is its the same as car body)
    Yellow and Red are the audio signal wires L, R speaker channels..
    So to do source alternation just cut Y, R cables and and connect them to Y-Switch, or phygigets bord, or mp3car audio switcher....
    I will post the pix when i get my camera back..
    PS: this trick only works for mers models 94-98 (doesnt work on ML) as new models have optical source from CD. Older models have tape dack that might have similar things but I never had a tape dack even on my old 300D '85
    Oct 2008
    Thanks for sharing the info. Unfortunately my head unit is Becker BE 3100 and the car is MB CLK W208 year 2001 and the head unit is equipped with the noticed optical plug - D2B so it comes very complicated to connect what ever external audio source.
    There is a few ADC converters for D2B that may be an option, but the prices starts from $300. Also some of them are noticed over Internet as sources of problems.
    Anyway, thanks...
    Jun 2007
    New York
    well since im mers only person and i will have to upgrade eventually to a newer model... i could try to find easy solution for optical network too... but i guess you are not in NYC so i wouldnt have access to the device...
    Jun 2007
    New York
    How about this one:
    http://www.hdwise.com/product.php?productid=402
    PS: I think you need DAC and not ADC converter...
    The link I gave you might work, but what I'm courious about is that if mers used D2B as a home automation standard then they might allso included controll signalss within the cable... is so I guess you will need to split the cable ...
    Probably easier way is to go to the AMP on the trunk and to the analog switch there rather then messing w/ the optics... so run 2 wire shilded coax back to amp and intyercept the signal there... unless you got noncertible, it should be like 2 hours of work
    Oct 2008
    Thanks. I`m not from NYC, I`m from Bulgaria, this is Eastern Europe.
    I need exactly the ADC because the sound comes analog from the MP3 player or carputer or what ever sound source, than it is converted to digital D2B signal and inputs into the head unit. I have no external amplifier because Becker have 4 X 45W integrated amp which is enough for my needs. I have 8 speakers in my car - all speakers and head unit are OEM and work perfect with quite good acoustic.
    The head unit is connected to the CAN-BUS of the car and I can see the information on a big LCD under the speedometer on my cluster. Also have a steering wheel controls (volume, stations and phone) and speed dependent volume level. I like all this advanced options - thats why I want to keep the original head unit is have a perfect integration and compatibility.
    This is what I mean ADC: DICE and ECP / D2B Aux-In
    Jun 2007
    New York
    well in that case that is what you need,
    basicallu what you are tryying to get is something similar to Car2PC but for fiberoptic port
  1. VW Golf Stock head unit to PDA via CD Changer Port??
    By TheMiddle in forum General Hardware Discussion
    Last Post: 07-17-2009, 02:50 PM
  2. M-Bus? 3000GT CD Changer...?
    By Nihil in forum Car Audio
    Last Post: 01-27-2007, 03:02 PM
  3. Stock Cd Changer To Pioneer
    By TurboSRT in forum General Hardware Discussion
    Last Post: 08-07-2006, 10:27 AM
  4. Replies: 8
    Last Post: 07-07-2006, 10:42 AM
  5. running stereo audio to rf cd changer input
    By wh00ps in forum Car Audio
    Last Post: 02-27-2005, 10:01 PM
