yes
I just got finished with my box for the Pyle Pro 21250 21" sub. 107 db at one wat is some pretty damn good sensitivity. I could actually fit two of these things if I put the front one on an offset by moving it as far over to the right and put one on the back of the box on the left. BTW the right angle measurer is 22 (inside), by 12 inches (outside)
yes
1.9in x 2.9in -- 47mm x 73mm
So.... should I go for a second one?
im guessing your not to worried how good it sounds as long and it really shakes the car?
Those are some nice sensitivity numbers for a low frequency driver.
Did you spray paint it red? I searched the pdw21250 and it looks like it has a black paper cone. I dont know if it is a good idea to be applying anything damp (like paint) to a paper cone...
I did paint it, but not with spray paint, I used a special sealing paint first to treat the paper to make it resist dampness. 8 ohm PA driver, my amp runs real cool with 8 ohms. All of my speakers are 8 ohms.
Are you crazy, not really compared to...
http://www.diymobileaudio.com/forum/...ad.php?t=46687
How about the rest of the high efficiency system?
System always under construction
