The question was never answered about what you're looking to get out of your substage... What kind of music do you listen to and all of that information determines a LOT in the box design. Ordering a port isn't necessarily necessary... You could use a slot port. Heck, you can't even look at your port size until you have dimensions on your box, and know what frequency you're going to tune it to. Port-fire and driver-fire directions are also determined a lot by the desired result.
There is a TON of math that goes into building an enclosure correctly, whether it be for SPL, SQ, or even when it's purely a budget-build...
LinkBack URL
About LinkBacks
) chamber to make room for the amp. and these dimensions still would allow the box to fit in the trunk
