Do you still have the factory radio, or an aftermarket radio?
The most likely thing that is happening is that one or more speaker lines are grounding out on the chasis from either behind the radio or at the speaker terminals. Aftermarket radios have a protect mode it's internal amp automatically goes into once a speaker line grounds out to protect the radio from the wire grounding out. It may be difficult to find out if it is an intermittant problem, but while the car is at rest and if it does happen you can test the speaker lines using a digital multimeter to test for continuity between ground and the speaker wire.
LinkBack URL
About LinkBacks
