Results 1 to 4 of 4
Thread: 2400 Digital amp constant thump at 0 Vol
    Oct 2008
    Exclamation 2400 Digital amp constant thump at 0 Vol
    hey guys my amp i recently bought gives a constant thump when i raise up the gain on the amp to my 15" alphine speakers, when the gain is at very low level its fine but when i try to raise it up my whole car shakes because of the thumping even at 0 volume , i tried hooking up my 800watt amp and it works perfectly, maybe i ened more power for the digital 2400 or special cables? any ideas? thanks.
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    A.) Sounds like you have a grounding issue.
    B.) Have you ever looked into properly setting your gains?
    Play with it, 'til it's broke.
    Oct 2008
    what you mean , but my 800watt worked fine all the way up and this one i cant crank it up much highers then like 10%/100% then it starts making the constant thump and the higher i put it up the higher the sound thumps...
    Nov 2006
    North Hollywood, CA
    I had this same issue with a crossover I was using. I'd be careful 'cause it burnt out two sound cards before I figured out what was causing the problem. I don't know how to fix it though. I am sending my amp back to the manufacturer for them to look over it and make sure there are no issues. As far as the crossover, I dismantled it and put it away 'cause if it's the crossover, it's not worth dealing with the trouble... if it's the amp, then it fried the crossover. I'll be doing all the crossover duties from the computer now.
    In my case, as soon as I turned the gain on my crossover to half (gains on the amp were all the way down) I started getting this weird thump/wack noise over and over again until I pulled the audio cables off. I realized there was a serious problem when the last time I was testing, I felt the RCA cables hot to the touch. Some seriously weird internal short circuit.
    I'd advise getting it fixed/replaced.
  1. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
