Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Audio Capacitor Wiring Question
    Low Bitrate ajscomp372's Avatar
    Mar 2006
    Buffalo, NY
    I have seen several different guides as to how to hook up an audio capacitor, but some say to hook it up inline on the 12V line and others say to hook it up in parallel. I thought that if it was hooked up inline, then I wouldn't have to worry about the current flowing backwards into the rest of the car if the car's voltage dropped for a moment, but then I read on wikipedia that this backwards current (reverse bias) can destroy an electrolytic capacitor. So, in conclusion, I want to hook up the capacitor so current won't flow backwards (if possible), but I want to know that if I hook it up in that way, the capacitor will not be destroyed. Are my assumptions correct? How should I connect the capacitor? Please let me know.
    Nov 2006
    North Hollywood, CA
    If by "in parallel" you mean battery > cap+ | cap- > amp +
    Then no. If not, then not sure what you mean, but all + power leads connect together. Power meaning non-speaker + just power distribution. Alternator + to battery + to cap + to amp +... likewise, keep power grounds together.
    The other way may work, but it's not a good idea. You may kill your cap, you may brown out your amp. Your amps draw current, so you want to always put the positive lead on the positive lead of the power source. Many men have melted jumper cables assuming that car batteries were meant to be wired like a pair of Duracell AA's. =O
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    there is no alternate way with cap:
    if the voltage drop is too high during engine start, then the battery should be replaced. put the cap as close as possible to the amp, less than 30cm required for real effect...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Low Bitrate IonDokk's Avatar
    Michigan
    is true only way to hook it up personally I like to keep the chassis grounds in the same place...
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
    Nov 2006
    North Hollywood, CA
    I've actually hooked up a cap on an amp the other way to see what would happen and the amp turned on and produced power, but it would go into protection mode whenever the bass was about to hit.
    Mar 2006
    Buffalo, NY
    It's not that the voltage drops too much when the engine starts, that's not the problem. The problem is that when I'm driving, on occasion, the voltage will drop when I'm braking (I have no idea why) which causes the PC (sorry I wasn't quite so specific before) to hang. But before you ask, yes, I've checked the alternator, and the battery is virtually brand new.
    Thanks, also, for the cap wiring diagram.
    Nov 2006
    North Hollywood, CA
    Does it happen just because of the brake pedal being pressed or the change in motion? Can you make it happen when the car is stopped and you press the brake pedal?
    Nov 2008
    Here's the real scoop on caps
    Here's the real poop.
    A capacitor's impedence (resistance) varies inversely (one gets bigger the other gets smaller) with the frequency of the signal. DC frequency is zero so a capacitor acts like an open circuit (connection). The whine we hear has some frequency much higher than DC or zero. The higher the frequency the less resistance to ground.
    OK, all that said the capacitor should be connected between 12+ and ground for it to work as filter to pull off the whine and shunt it to ground. The reason it "sort of worked" in series is this. Most of the non zero frequency sound, cymbals, guitars vocals etc pass through the cap. The real low grequncy stuff, bass guitar and bass drum, are close to zero so the cap acts as an open circuit, thus causing protection circuit to isolate from amplifier.
    Best of luck. Remember too, the bigger the cap the better.
    Mar 2006
    Buffalo, NY
    Hmm.. I'm not sure. I'll have to hook up my multimeter and test it tonight.
    Nov 2006
    North Hollywood, CA
    Quote Originally Posted by GTSparkey View Post
    That might be taken to mean a 20F batcap is better than a standard canister cap. The canisters are quicker to react than a batcap, which is why you use them in the first place.
  1. Audio Question Turtle Beach Roadie
    By 92jdmx in forum Car Audio
    Last Post: 01-05-2007, 08:15 AM
  2. Question about my audio setup
    By djSALIX in forum Newbie
    Last Post: 11-28-2006, 07:37 PM
  3. Laptop Audio Question
    By InVisioned in forum Newbie
    Last Post: 09-25-2006, 02:39 PM
  4. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 04:06 PM
  5. PAC Audio Aux input amp pop question
    By knubile in forum Car Audio
    Last Post: 05-03-2005, 08:28 AM
