How do I set that? I haven't been able to change the volume for it at all besides the master volume. That could very well be it if I can find where to change it.
What's your line-in recording volume set to?
The procedure listed above for checking that your MB is set to record on line-in only also gives you the gain on the line-in.
I had some issues like this when i was setting up my HD Radio with RR. I'm using the Visteon HDZ300 HD Radio Tuner. I first had it setup to a Intel D201GLY2A and it worked fine, then I upgraded to Intel DG45FC and w/ out changing anything with the radio it made horrible crackling noises and no matter what i did with the antenna or anything it wouldn't go away. What I came to discover is that the Visteon seems to put out a pretty strong audio signal and depending on the sensitivity of the input on your motherboard it can come in too strong and cause that distortion. I just went into the volume controls under Sounds in the control panel and turned the volume down for the Line In and it fixed it.
Then I had a slight hissing that could be heard if there was just talking on the radio or if there was silence on the radio, or anytime the Line In was un-muted and no significant sound was coming over that. To fix that I did this:
Mitch's Floating Ground Fix
Thanks guys, that pretty much fixed it. I will have to try the fix you pointed to on Mitch's site. I'll try to get that hammered out tomorrow.
OK, so after using the setup for a little bit I have realized that I have another problem. After setting up the line in plugin, winamp freezes when coming back from hibernation. It does fine coming on from a cold boot though. Let me know if you guys have any ideas on a fix.
I guess I'll just be cold booting till I get this fixed...![]()
