Results 1 to 10 of 17
Thread: Looking for a USB sound card that will pass through input
    Jan 2008
    Arnold, MO
    Like the title says, I need a USB sound card that will pass audio through the input "live" to the output so that I can use my HD radio. I am hoping for something fairly high quality without spending too much (<$100).
    I have spent the last couple hours searching and havent been able to find one that says for sure whether it is supported or not.
    Thanks for the help guys!
    May 2008
    Just curious. Why do you need "live" passthrough? I'm using line-in on my motherboard for the HD radio and passing it to the USB sound card for output.
    Jan 2008
    Arnold, MO
    right, what you are doing is exactly what I'm talking about, but unfortunately my motherboard doesn't support that. It will only record then play back, I need it to pass straight through. I am hoping to find a USB card that will accomplish this without spending too much.
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    pass through what? analog or digital input to analog or digital output?
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
    Jan 2008
    Arnold, MO
    I just need analog from the HD radio to pass analog on to the amps through the pc.
    May 2008
    Hungary
    Quote Originally Posted by bloodshot710 View Post
    what type of mobo (and sound chipset) do you have? i have never met integrated sound without this option, only some USB based... try to check the mixer settings again, this should work...
    May 2008
    Well, in RoadRunner, here's what you do.
    Install the Winamp Line-in plugin. Yes, it's old. Yes, it works.
    Under "Radio" in RRConfig:
    • Set "Line used for Radio audio" to "Disabled".
    • Check "Use Line-in Plugin". In the text box next to it you'll need something like "line://dev=1,title=Radio,srate=44100,bps=16,nch=2".
    You may need to change the dev=# to match your sound card. To find the right number, launch Winamp and configure the line-in input plugin. All your sound devices should be listed there with their device number.
    If that works, all well and good. If not, make sure that your motherboard is set to record on line-in:
    • Double click the speaker icon in the task-bar.
    • Select Options->Properties
    • Use the drop-down to select your motherboard's Mixer Device.
    • Click the Recording radio button.
    • Click OK.
    • Make sure "Select" is checked for Line-in and nothing else.
    • Close the Recording Control window.
    BONUS: Winamp visualizations and mixer controls will work with your radio with this setup.
    Jan 2008
    Arnold, MO
    Quote Originally Posted by Sicarius View Post
    • Click OK.
    Thanks! Just got the chance to work on it tonight, got it all working!
    Unfortunately there is a lot of noise in the line, almost sounds like it's clipping, but the volume is even lower than winamp. Any suggestions?
    Thanks a lot for the help!
    May 2008
    Let's check the silly stuff first.
    Is the radio in the car yet? Is it hooked up to an antenna? Does the antenna need power?
    Jan 2008
    Arnold, MO
    Yes, everything including the radio is set up in the car. It is hooked up to the original antenna that came with the car. As far as I know the antenna does not need power, I used it with this same HD radio before I had my carpc set up and it worked perfectly.
  1. usb sound card for audio tuning
    By Perrosky in forum Car Audio
    Last Post: 11-07-2007, 04:26 PM
  2. usb sound card
    By gti4dr in forum General Hardware Discussion
    Last Post: 10-16-2007, 08:24 AM
  3. Hardware Review: SB Audigy2 NX External USB Sound Card
    By hari-bhari in forum The Review Palace
    Last Post: 12-13-2006, 04:55 PM
  4. Replies: 5
    Last Post: 02-03-2005, 02:43 PM
  5. USB sound card
    By cjones in forum General Hardware Discussion
    Last Post: 01-27-2002, 04:25 AM
