Results 1 to 4 of 4
Thread: Eliminating Buzzing From CarPC/AC Inverter
    Feb 2006
    New Jersey
    Thumbs up Eliminating Buzzing From CarPC/AC Inverter
    I have a cheap 400w AC inverter powering my CarPC setup. I have always had problems with buzzing since I switched to this inverter. I recently changed my head unit and then the buzzing increased. I tried everything.. moving wires around, checking grounds, and even tried ground loop isolators. The ground loop isolator helped somewhat, but nothing acceptable. I finally tried grounding the case of the computer's power supply directly to the car with a foot of wire. This totally took ALL buzzing and noise away immediately. I have never had crisp and clean sound like this before. I am just putting it out there for anyone else having these issues.
    Elsewhere
    This is one reason that inverters suck.
    I would also guess that your PC PSU is a cheap no-name brand, as well.
    Why is this in the FAQ section?
    How about the Wiki?
    Feb 2006
    New Jersey
    My PSU is an IBM PSU and grounding the computer to the car totally took away all buzzing and noise. I get to use a cheap inverter without any of the consequences.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Quote Originally Posted by DarquePervert View Post
    Cause I haven't moved it yet.
  1. Inverter now cauzing buzzing noise?? wtf?
    By Yellow-Snow in forum General MP3Car Discussion
    Last Post: 11-11-2006, 02:13 AM
  2. Fixed My Buzzing with AC Inverter
    By jjcuff1 in forum General Hardware Discussion
    Last Post: 02-02-2005, 10:15 PM
  3. Help Eliminating Inverter Noise - Options
    By prospero in forum General Hardware Discussion
    Last Post: 04-21-2004, 02:37 PM
  4. inverter buzzing
    By brandondere in forum General Hardware Discussion
    Last Post: 06-09-2001, 06:06 PM
  5. eliminating inverter
    By Smacker in forum Power Supplies
    Last Post: 04-12-2001, 01:58 PM
