Results 1 to 3 of 3
Thread: Motorised multichannel volume control/preamp
    Nov 2008
    We doing some all out prroject and planning to use ever super quality PCI card(modified Lynx) or stack of external hi-fi USB DACs, but it's all meningless if volume is controled in digital domain. Need to find at least 6 channels volume control with remote so we could pass that wonderfull quality sound
    _
    Mar 2004
    Little Elm, Texas
    Good luck finding a stepped attenuator with more than 6 channels that actually tracks close to each other.
    You're going to be hard pressed to find one that does even 2 channels, let alone more.
    Sounds like you want to have a great sounding solution but don't want to put any research into that solution. I have to wonder, what kind of satisfaction do you get out of that if you didn't do anything but just put it together?
    Jan Bennett
    Nov 2008
    Quote Originally Posted by RedGTiVR6 View Post
    Actualy it's funny - it's a reostat pods do not track close. Beauty of SA is what they track perciesly(within toleraces of resistors) - hence the steeped part, The only problem with them is cost of the decent once starts at $80 for channel and ammount of torque needed to move 3 pairs calles in for complex motor/reductor assembly. Add to it cost of decent input/output buffers to preserve dynamics and you will understand why I would like to look for a commercal solution.
    And nowere on this forum such solution has been discussed - at least according to the search .
    My other alternative is to use a digitaly controlled gate devices such as AD 12bit VC used by Pioneer ODR processors - but I do not like what they do to the sound.
    As far as putting things together - I have good 300+ hours of ressearch, soldering, programming and integration in front of me. Guess what - they not going to bring me satisfaction - but end result - well integrated, fully functional and GREATE sounding system will bring me all the satisfaction in th world
  1. Volume problem with RR.
    By Outsider787 in forum Road Runner
    Last Post: 08-01-2007, 02:45 AM
  2. Road Runner Volume Issues ! ! !
    By rewindnottm in forum Road Runner
    Last Post: 03-20-2007, 04:38 AM
  3. Replies: 6
    Last Post: 02-20-2007, 03:13 PM
  4. Replies: 11
    Last Post: 02-11-2004, 11:59 AM
  5. Multichannel sound volume control for Epia-M
    By Alric in forum General Hardware Discussion
    Last Post: 12-04-2003, 08:51 PM
