Results 1 to 10 of 14
Thread: '08 Lancer wiring diagram
    Oct 2007
    Hi!
    I'm planning to install an aftermarket HU in the mitsubishi lancer 2008.
    My question is : Does anyone have the wiring schematics or harness pinout ?
    I've found like 5 different things,and none of them have the connector like mine.Hiere's the picture of the connector.
    If that's not possible i'm gonna redo all the wiring,but how to find out wich1 are the speaker wires so i don't have to tear apart the door panels.
    cheers and thanks !
    P.S.
    FLAC WuNgUn's Avatar
    Sep 2007
    Oct 2007
    i'm heaving trouble to find the wiring for the 08 lancer.
    i have the harness for the earlyer lancers but it doesn't fit
    Sep 2007
    Maybe these guys can help you...
    http://www.mitsunation.net/forumdisplay.php?f=134
    Oct 2008
    Pa
    I did a write up for this on another forum. Here you go.
    http://forums.evolutionm.net/showthread.php?t=373383
    Oct 2008
    Pa
    if you just need a wiring harness order one from crutchfield, i did.
    Oct 2007
    Quote Originally Posted by strife View Post
    so at the end it will work as the normal harness?
    Oct 2008
    Pa
    I don't understand the question.
    At the end of what?
    The post I did was to make a aftermarket head unit work with the factory Fasgate amp. If you don't have the 650 watt Fasgate system you just need the wiring harness from any audio shop.
    Oct 2007
    if i understad correctly...
    If i wire this way,i won't be able to fade between front/rear ?
    Oct 2007
    oh yes...i forgot to mention,i don't have the premium rockford fosgate system
    i have a DE package.
  1. audio wiring diagram needed 2005-2008 Jeep Grand
    By ajm1555 in forum Car Audio
    Last Post: 07-24-2008, 02:58 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. AutoPage 860 + 2000 Honda Civic Wiring diagram Help!
    By pcmofo in forum Hardware Development
    Last Post: 01-14-2007, 07:19 PM
  4. Wiring diagram for Opel Corsa
    By wade in forum Car Audio
    Last Post: 10-10-2005, 04:56 AM
  5. datalux 4x20 red lcd wiring diagram?
    By etrik in forum LCD/Display
    Last Post: 12-07-2001, 04:35 PM
