My setup:
Deck -
Pioneer Premier DEH-P400UB
Subs -
Two Pioneer Premier 12" Champion Series PRO Subwoofers with 3000 Watts Max. Power Wired at 4ohms 600watt RMS (each)
I can't exactly remember the mids and highs, but I know I have two pioneer premier 6x9's and two 5 1/4" components. (can't remember the wattage exactly)
Pioneer 4-Channel Power Amplifier with 600 Watts Max. Power (hooked to mids and highs)
Pioneer Premier™ PRS-Series Class-D Mono Amplifier with 1200 Watts Max Power Two of these one to each sub
Tsunami 5 Farad Capacitor
Planet Audio Two channel line driver (8v output)
Here is my problem: (
lights dimming now)
I have a 95' Ford Taurus 3.0L V6, comes stock with a 130 amp alternator. I also upgraded my battery when I got my system to the Optima red top battery.
When I got my system everything was fine, I've had it for almost a year. It is setup to where I put the volume at 48-50ish is perfect. When I have it there my lights dimmed a little bit, but I'd have to really look for it to notice. (which wasn't a problem)
However the past month or two my lights have been dimming a lot. They are even starting to dim when my volume is at 35. (and they dim more at volume 35 now than they did when my volume was at 48 or 50 a few months ago).
So I had some things tested, I thought it was finally my alternator going out (since it's still the stock one). Autozone had tested everything didn't say anything was wrong, then checker tested stuff said the battery was putting out 300ish cold cranking amps when it's supposed to be putting out 800 minium. They said the battery it self was fine but the alternator wasn't charging it like it should. Which after driving it I noticed the lights dimming more and more and having to lower my volume down to like 25-30 to avoid dimming. So I figured he was correct, and my alternator is slowly going out and my battery is taking up the slack.
Now to make this long story a bit shorter:
I replaced the alternator (after market 130amp (highest I could get))- No change
Had a battery store test my battery and alternator (they were both fine (even my old alternator))
I had the audio store that installed my system check the cap, everything seems to be fine,
displays 14.5v, around 12ish when the volumes all the way up, and it's also displaying the output it's giving to the amps. (ranging anywhere from 0-110 amps average is around 40-50 though)
So I thought maybe it was
wiring, just did the Big 3 upgrade, 2 gauge welding cable, also no change.
Now the last option I can think of is the alternator (this is what every store is telling me, I need more
power) But my issue with that is, how come when I got it a year ago, with the stock alternator, my lights hardly dimmed at all. (with the exact same setup, in fact minus the big 3 upgrade) and now it's all the sudden worse than it's ever been. (Even with the new alternator that I still have in there currently)
Nobody has yet to answer that question, they just say there is not enough input power to supply everything. If that really is the problem I will get a HO alternator (which I planned on doing when I first got my system).. Money is tight right now though, and I don't want to buy a HO alternator and for some reason have the same problem.
It would be appreciated if someone could explain why it's dimming now, and wasn't before with the same amp alternator, and if in fact I do need to upgrade to a HO alternator. Also if I do need to upgrade how much amps will be enough? (keep in mind a little dimming isn't a problem, like it was originally, but when it's dimming to about half the brightness, that is. It is also not JUST my headlights that dim either, my clock inside my car dims, my capacitor in the trunk also dims, pretty much any light source (I haven't noticed my deck dimming though))
