Results 1 to 4 of 4
Thread: Earth
    Jul 2007
    Sheffield, United Kingdom
    Earth
    I heard that you shouldn't use the same earth/ground for a cap and amp, is this correct? or does it matter?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Never heard of this theory. If anything, I would say all your audio equipment should use the same ground to reduce the possibility of a group loop.
    Nov 2006
    North Hollywood, CA
    When it comes down to it, all electronics in a car share the same ground. But different parts of the car have different ground potential. Potential is highest where current flows so if you have a large current grounding at one point (a few amps here) and your head unit somewhere else, chances are ground potential will be different at the two ground points, which can introduce noise. I think that's how it goes...
    Not sure how much difference it makes with a cap, but I always ground everything to the same spot.
    Jul 2007
    thanks for the advice guys
  1. Cacheing Google Earth Roads
    By Pandaman72 in forum GPS
    Last Post: 05-14-2008, 12:19 PM
  2. Google Earth -Programming
    By zapwizard in forum MacCar
    Last Post: 03-10-2008, 11:00 AM
  3. Google Earth with VIA EPIA EX10000
    By jamedinar in forum GPS
    Last Post: 06-21-2007, 06:42 AM
  4. Hmm...from where on the inverter do I earth!
    By Meoff in forum General Hardware Discussion
    Last Post: 07-09-2000, 11:05 AM
