Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Volume with car off and none with car on. Why?
  1. #11
    Dec 2008
    yeah all worked fine before the current sub set up. i had my girlfriends sub hooked up to it with the same amp and all was fine. but i will go give the remote short a shot.
  2. #12
    Dec 2008
    well that looks to be the problem. the JL amp is rocking and when i plug the Alpine it cuts off. I guess i will try to run a wire from the HU's remote turn on point. that way they aren't both coming from the same source.
  3. #13
    Constant Bitrate scatebase's Avatar
    Oct 2008
    Did you have the cap before also? That might be causing problems.
  4. #14
    Oct 2008
    The turn on lead probably cant handle turning on everything. You could connect the turn on lead to a relay that would connect 12v from the batt when the remote turn on is triggered.
  5. #15
    Dec 2008
    please explain to me more about the relay, where i could get one and how i should hook it up. that sounds like the best idea. thanks for the help
  6. #16
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Quote Originally Posted by btaylor View Post
    Any automotive store for less than 5 dollars, there will be a digram or just google it, they are all pretty standard.
  7. #17
    Oct 2008
    you could pick one up at radio shack or some auto part stores. You just need a 12v automotive relay. http://www.radioshack.com/product/in...77&tab=summary
    Here are some links with info on hooking it up:
    http://www.diymobileaudio.com/forum/...mote-turn.html
    http://www.oznium.com/forum/topic10892
  8. #18
    Dec 2008
    Awesome. I knew it was something simple. Thanks alot guys.
Tags for this Thread
