Results 1 to 3 of 3
Thread: how do i hook up subs to stock monte radio
    Dec 2008
    i have all the wires ran and i have a little switch which is my remote rca's are hooked to spliced rear speaker wire and i cant get any sound from the sub idk what else to do any suggestions?
    Constant Bitrate scatebase's Avatar
    Oct 2008
    You cant connect RCA cables to speaker cables. They are different levels. Most manufactures use the term High level or speaker level for speaker wire, and line level, pre-amp level, or low level for RCA connections.
    If your amp has High level inputs, that is where you need to connect the wire from the rear speakers. Be prepared that the quality isn't as good as line level. The best solution is to run shielded RCA cables from the head unit to the amp.
    Dec 2008
    some one told me something bout a high to low converter? would that work better and sorry i am new at this im confused by your post
  1. Replies: 6
    Last Post: 06-03-2008, 09:02 AM
  2. Stock Radio won't kick on?
    By IntellaWorks in forum Car Audio
    Last Post: 11-03-2005, 01:36 PM
  3. WTB: Honda stock radio. (must be amber colored!)
    By justintime in forum Classified Archive
    Last Post: 06-23-2005, 01:05 PM
  4. Replies: 3
    Last Post: 05-18-2005, 04:58 PM
  5. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
