Results 1 to 2 of 2
Thread: Sound Blaster 24-bit issues
    Dec 2008
    I'm not really sure this is the appropriate place to ask this question, but here goes...
    I own a 2003 Mustang with the Mach 460 sound system. It has 4 subs and 4 tweeters (two of each in the front and rear). When I built my CarPC, I used all three output jacks on my sound card. The first jack goes to the front tweeters via a 350 watt amp, the second goes to the rear tweeters via the same amp, and the third goes to the subs.
    The problem I'm having is with the subs. Each channel from the third jack goes to either the front or rear subs via their own respective (factory) amps. The only way I can get the sound card to use the third jack is by setting it to 5.1 and upmixing it (CMSS). Obviously this is not ideal since it treats the front subs as a center, effectively eliminating my front subs, and instead playing only muffled highs through them. Additionally, Dolby Digital sound is even worse since I loose all sound that would otherwise come from the center... which seems to be mostly speech.
    Of course, Creative's software is built for the perfect idiot and absolutely will not let me dictate what channel does what. kXProject is out, as it is not compatible with my sound card.
    So. My question is this: What options do I have?
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Simply buy a y-splitter and split the one for sub. Leave the center blank if your not using it. Thats pretty much the only way. It has to be on 5.1..... 4.1 doesnt work in the car enviroment for what we want to do.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  1. Sound issues from headphone jack
    By iamgnat in forum MacCar
    Last Post: 09-24-2007, 11:23 PM
  2. Sound Quality Issues
    By tigergibb in forum Car Audio
    Last Post: 08-11-2007, 12:55 PM
  3. Sound card issues
    By gboy in forum Newbie
    Last Post: 02-25-2005, 10:38 AM
  4. Replies: 0
    Last Post: 03-10-2004, 12:34 AM
  5. Sound Blaster mp3+ vs. M-audio sonica USB Sound Cards
    By pogue1000 in forum General Hardware Discussion
    Last Post: 02-09-2004, 05:04 PM
