Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Noise/Buzz in audio Please Help
  1. #11
    Dec 2008
    No...No...don't go away
    is grounding motherboard safe.....should i ground it with negative of battery or just any metal surface.....can i run three separate wires from all screws and join them together at negative terminal of the battery.
  2. #12
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    Quote Originally Posted by smhussain View Post
    you don't need any help on the PC you need it elsewhere, all the info to help you is already posted here.
  3. #13
    Dec 2008
    I have to mount my motherboard without case in the glove box.
    So what are my options. What am i not getting here. Please tell me. It will take a little time to write in detail but will eliminate any further questions from my end.
    Just tell me what is the appropriate way to mount motherboard without casing and i shall do accordingly.
  4. #14
    Oct 2007
    honestly, are you really that ignorant or just hard headed?
    Your computer is likely to be the most expensive and most delicate part. It belongs where it was designed to be: inside a case.
  5. #15
    Dec 2008
    honestly what is with all the attitude. If you are all that knowlegable why not just reply to what was asked in the first place instead of going on with this big charade.
    If you mean to be this arrogant why do you even come to forums which is usually full of noobs like me.
    and btw, what is wrong with installing a computer in glove box. Many people have done it. I just wanted to ask what is the right way to do it. If you don't know, stop giving me crap.
  6. #16
    Oct 2007
    honestly what is with all the attitude. If you are all that knowlegable why not just reply to what was asking in the first place instead of going on with this big charade.
    Look, I just explained to you three times where a motherboard should be placed, and how it should be mounted. I also told you how it must be grounded. It's up to you now to stick it in the glove box. You are proving here how truly incompetent you really are.
    If you don't understand, maybe a computer is not something you ought to be handling.
    I am glad you are not asking how to mount an LCD without a case, because you can come in contact with very high voltage. If it doesn't kill you, perhaps it will jar some of your brain cells into a state of comprehension.
  7. #17
    Oct 2007
    Quote Originally Posted by dmand View Post
    as stated in my previous post, the motherboard must be mounted properly using standoffs attached to a metal chasis.
    otherwise, you may end up having to ground all of the screw points that are supposed to secure the board.
    furthermore, taking a shortcut by incorrectly attaching wires to the screw points without soldering them, and then placing the board on a plastic surface will only make your situation worse.
    Good night
  8. #18
    Mar 2006
    Blog Entries
    1
    Simple fix, spend $10 on a ground loop isolator problem solved.
  9. #19
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Offensive posts removed, infraction issued. Time to close this thread and move along.
    Want to:
  1. Outputting from car audio head unit to home theater receiver
    By mach5 in forum General MP3Car Discussion
    Last Post: 05-31-2007, 12:20 PM
  2. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 04:06 PM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  4. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  5. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 02:44 AM
