Results 1 to 3 of 3
Thread: Hot Audio DACs
    Constant Bitrate Hessian's Avatar
    May 2007
    Hot Audio DACs
    Has anyone tried these DACs?
    http://www.hotaudio.com/zen-cart/ind...4d86944972bc45
    There are a couple different variations. I'm looking for something to feed my 3sixty.2 processor. The MARK IV looks like a good choice at $140.
    May 2007
    Mark IV Specs
    The DAC on the Mark IV is a Burr Brown PCM2705 (USB and DAC). I'm not sure of the opamp.
    The Hippo HIfi Bloat for comparison uses the PCM2707 chip for USB combined with the PCM1794 DAC, but for $229.
    I'm not sure how much of a difference this will make in sound quality out of the USB port which is 16bit. Both seem to use USB 1.1 from what I can tell.
    I'm new to DAC technology. So I'm learning as I go. Dave at HotAudio has been great in answering my questions.
    Other Mark IV Specs :
    THD+N when driving a 16-W load is 0.03% at 1 kHz
    THD+N when driving a 32-W load is 0.02% at 1 kHz
    THD+N when driving a 10-kW loads is 0.005% at 1 kHz
    Thermal and Short-Circuit Protection
    Sampling Rate: 32, 44.1, 48 kHz
    Has 3.5mm Stereo Headphone Output Jack on front
    Left and Right Gold plated RCA line level outputs to drive power amplifiers, receivers.
    Dimensions: 65mm by 65mm by 30mm ( 2.5 inches by 2.5 inches by 1 inch )
    Weight: Approximately 100 grams
    Extremely Low Jitter
    USB 1.1
    Chips:
    http://www.digchip.com/datasheets/pa...77/PCM2705.php
    http://www.digchip.com/datasheets/pa...77/PCM1798.php
    http://www.digchip.com/datasheets/do...number=PCM2707
    May 2007
    I've been reading this thread on the Hot Audio DACs.
    http://www.head-fi.org/forums/f5/hot...s-amps-242880/
  1. audio over USB v. optical
    By RedGTiVR6 in forum High End Solutions
    Last Post: 03-01-2011, 02:26 PM
  2. Audio Interrupt "Black Box" for Stock Head Unit
    By jmciver in forum Hardware Development
    Last Post: 10-11-2007, 03:15 PM
  3. Outputting from car audio head unit to home theater receiver
    By mach5 in forum General MP3Car Discussion
    Last Post: 05-31-2007, 12:20 PM
  4. some audio questions for my setup
    By PatrickB in forum General MP3Car Discussion
    Last Post: 05-11-2005, 08:37 AM
  5. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:10 PM
