Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Mixing down 2 sources into 1
    My car stereo has an RCA Aux input. I have 2 devices that I want to plug into this input. I have read about switches, and that's not what I'm looking for. What I am looking for is more like what a sound mixing board does: taking multiple inputs and allowing them to be heard at the same time on the same output. Is there anything out there that does this and is small enough to fit into a car without a problem? I am basically looking for a 2 channel mixer. Any advice here would be greatly appreciated.
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    The mixer you're talking about are mostly for DJ's and stuff, so I dont know if you're gonna have a mobile one. Dont know why u would want to listen to 2 different source though, unless you're a mixing DJ.
    My carpc worklog
    I've got an iPod and a GPS to hook into the car stereo.
    Jan 2009
    I had this same issue, and it's pretty easy to build one yourself. You just have to make sure each input has a resistor in-line with it. Take a look at the schematic here. You just have to wire that together for both left and right. That circuit doesn't have any level adjustment, which is often not a problem, as you can adjust the output level on the devices themselves. If it is an issue, though, there's another circuit that includes potentiometers to allow basic mixing.
    Nov 2008
    Then you probably just want an audio jack Y cable that lets you connect 2 inputs at the same time.
    [media]http://img.alibaba.com/photo/205180948/3_5mm_PLUG_MALE_TO_2_JACK_FEMALE_Y_CABLE_STEREO_AU DIO.jpg[/media]
    You can hook both up and they will work fine, if you play them both at the same time it will play them over your stereo at the same time too.
    Jan 2009
    Quote Originally Posted by shatteredzman View Post
    You definitely don't want to do that. Each device tries to force the other device to a different voltage, and it can ruin the output of the devices.
    Nov 2006
    North Hollywood, CA
    Except you want 4 RCAs to 2. Two of these:
    Put the two lefts on one and the two rights on another Y-adapter and then plug the two adapters into the RCA's you have available.
    Nov 2008
    Quote Originally Posted by HyperZulu View Post
    I thought ipods used audio jacks? I dont know because I dont own one. But if it uses an audio jack you can get an rca adapter. All the adapters listed so far come in different combinations of male/female ends so get the one that is the easiest to use.
    [media]http://www.rueducommerce.fr/hifi/images/produits/info/xl/HRCA.jpg[/media]
    [media]http://img.alibaba.com/photo/205246107/3_5mm_1_8_Female_Mini_Jack_to_2_RCA_Plugs_Audio_Ca ble.jpg[/media]
    [media]http://www.usbcables.com.cn/Upload/product/200681622264822955.jpg[/media]
    Jan 2009
    Mixing 2 audio sources
    Basically, you can mix them by directly connecting them together (preferably through small capacitors).
    As the guy below mentioned, you may need to tweak levels though, with
    resistors. So its a sub-optimal solution. You could design a more complex
    circuit.
    However, also, chances are if the two inputs happen to be (say)
    an MP3 player and a handsfree speakerphone, then you may want to
    drop the volume slightly on the music when the handsfree speakerphone
    kicks in.
    For that, you need a more complex circuit. But, believe it or not, you can
    still use relays to achieve all this, in a quick but effective method.
    Here is the diagram: [media]http://home.btconnect.com/shabaz/misc/audiomixing.jpg[/media]
    (it only shows one channel e.g. left, you need to repeat it for the right channel using the other half of the DPDT relay).
    When the relay is not energised, then most of the volume is from the MP3 player (some slight leakage of sound from the phone, but unlikely since there is no phone call yet). When the phone rings, you need to arrange for the phone kit to activate the relay. This will switch most of the phone volume to the output, and a reduced level of music. There are other ways of doing it, but this is a quick idea.
    Jan 2008
    Covina, CA
    U guys do realize that by using that Y-splitter will probably damage the 2 sources? Youre basically feeding an audio source into the output of the other source.
    My carpc worklog
  1. Can I connect 2 sources to one speaker?
    By HiJackZX1 in forum Car Audio
    Last Post: 12-10-2008, 02:49 AM
  2. inputing multiple audio sources via 5.1
    By customstevo in forum Car Audio
    Last Post: 11-28-2006, 01:01 AM
  3. Fiberglass mixing
    By theprojectpat in forum Fabrication
    Last Post: 06-19-2006, 05:02 PM
  4. Replies: 6
    Last Post: 04-01-2005, 02:44 PM
  5. Replies: 4
    Last Post: 04-16-2004, 02:02 PM
