Results 1 to 4 of 4
Thread: What size in line fuse needed
    Jan 2009
    i am installing another, bigger amp to hook up more subs and was told you need a main in line fuse right next to the battery and then two more after the ditrabution block and was wondering if that is correct and what size in line fuse should i use for a 1800 watt amp?
    Elsewhere
    For a safe installation, you need a fuse as close to the battery as possible.
    You should also fuse any lines where there is a change in wire size, which usually means after a distro block.
    As far as the fuse sizes you need, we can't tell you without knowing the total amperage the equipment will draw.
    There are tons of guides to choosing proper fuse ratings on the web. I'm pretty certain there's one on these forums, as well.
    Now tell us about your carPC....
    How about the Wiki?
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    look at the fuses built into the amp itself, most have one.. and add them all up,
    make sure what ever you put in is bigger than all of those together.
    real basic math 1800W / 14V - 130A (ish)
    when you find out the RMS wattage put that into the equation instead
    and i would suggest getting a breaker not a fuse
    Dec 2008
    BCAE System Power Design Assistant
    If your amp is class D be sure to choose that. If you don't know the efficiency of your amp leave it at what they have
  1. bluetooth woes
    By gentoocar in forum Linux
    Last Post: 12-12-2009, 04:05 PM
  2. Igniton Fuse Keeps Blowing
    By TeamRSX in forum Power Supplies
    Last Post: 05-06-2008, 11:02 PM
  3. onboard sound, no line in
    By TeamRSX in forum Car Audio
    Last Post: 04-08-2008, 10:57 AM
  4. Fuse Size Suggestions
    Last Post: 12-31-2007, 01:26 AM
  5. MCI error 261 and 263
    By genesis66 in forum Road Runner
    Last Post: 12-21-2007, 02:59 PM
