Well yeah, exactly. If you've used audio equipment enough, you'll kind of get an idea of where to set the gains in order to achieve the max power you are looking to get. If you have a head unit that has 4v preouts, you won't want to set the gain too high... 8v preouts and you should be all the way down on the gain. But if you're using a carPC and you have onboard sound, your gains will be much higher up to get to 7,8,or 900w...
There's a more technical way to do this, using a multimeter and test tones to read the voltages, that will allow you to get exactly how much power the amp is pushing.
LinkBack URL
About LinkBacks
