Results 1 to 2 of 2
Thread: Line out converter problem need help!
    Jan 2009
    hey i have a 09 jeep wrangler with stock infinity sound system, with stock amp/sub i currently installed my aftermarket sub/amp using a lineout converter with my stock headunit, after getting everything hooked up it all works but i am getting hardly any movement from my sub? no matter what the volume the power of the sub stays the same it seems
    Low Bitrate edge2k's Avatar
    Jan 2009
    Daytona Beach, Fla
    Try connecting the 2 pairs of wires to the stock sub speaker wires (since there isn't any left/right separation) if you have them tapped into the mids, the sub output probably has a higher voltage then the other speakers plus it still gives you sub control from the stock deck, if that doesn't work (if there is one) try adjusting the line level knob to a higher setting.
  1. Tutorial for installing pycar on Linux
    By kbyrd in forum PyCar
    Last Post: 11-01-2006, 01:59 PM
  2. how to install a line out converter on a 97 saturn
    By bobby_n1 in forum Input Devices
    Last Post: 09-15-2006, 11:02 PM
  3. Replies: 0
    Last Post: 11-02-2005, 11:25 PM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  5. Line converter with a Delco Bose system?
    By JGeek in forum Newbie
    Last Post: 03-27-2004, 02:46 AM
Tags for this Thread
