I have a
laptop in my work vehicle and decided to hook it up to the stereo so I could listen to my
music and audio books. At first I just used a standard 3.5mm cable, but was getting the hissing noise, so I went to
Radio Shack and purchased a ground loop isolator, but I am still getting hissing noise when ever the inverter is turned on. If I run the laptop off its battery, its crystal clear, but as soon as the inverter is turned on it turns into a mess. I've tried a 350 watt inverter and I also tried plugging it into the 1000 watt inverter I have installed, both had the same result.
