they can both control volume, but if you're using a headunit then you should leave the PC volume up all the time and use only the headunit as the master volume.
could be an impedance mismatch (with the headphone output), or the line-level voltage might be higher than the headphone output, or both...
yes
LinkBack URL
About LinkBacks
