Results 1 to 10 of 15
Thread: Advice Needed for 3 way Active Setup
    Low Bitrate Cycfari's Avatar
    Nov 2006
    N1 22.921 E103 54.207
    I'm planning to run a 3 way active setup on my car front speakers with my CarPC as the source.
    Does anyone had any experience with using DAC analog out into a sound processor?
    Will the H701/P9 or 3Sixty.2 sound processor accept an analog input from the DAC?
    Will my following setup work??
    PC-->USB DAC-->H701/P9 or 3 Sixty.2 processors??-->S44 Tru Amp (4 Channels for High & Mids) & Steg Q220.2 (2 Channls for woofers)--> Dynaudio 340
    Thanks & looking forward to any advice/comments...
    Nov 2006
    North Hollywood, CA
    Why not just get a card with digital out to go to the alpine processor? Any reason why you would want to get a digital signal converted to analog to be converted back to digital and the manipulated via the processor to them go back out as analog? When you can go digital source, digital out, digital in and analog out? I think one conversion keeps the signal cleaner.
    Keep digging around.
    Nov 2006
    Quote Originally Posted by HyperZulu View Post
    Thanks. I must have misunderstood the workings of the processor. My thoughts were if analog aux in was used, it will just do those EQ & TA tasks.. Didn't know that the analog signals will be converted back to digital for processing & then analog out again
    My mobo doesn't comes with digital output & it also can't support PCI soundcards due to its size/enclosure. I think i'll ditch my DAC & look for a USB soundcard with digital out instead?
    FLAC WuNgUn's Avatar
    Sep 2007
    Why not do all your DSP using the PC instead??
    Something like this (2-way)...
    I'm using a different crossover filter now (single 4-way + pass-thru), and my setup is a little simpler, but it works great...
    Nov 2006
    North Hollywood, CA
    Yeah I did all my processing on the computer using kx drivers on an Audigy2 card. It's PCI though. Not sure how to do the processing with other cards, but I'm sure it's possible. Saved me from having to buy a dedicated crossover or sound processor.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Hey WuNgUn, how do you like AudioMulch? I've used Console before but it was a little tricky to get working.
    Sep 2007
    Quote Originally Posted by Machinehead View Post
    Mulch is pretty decent...there is however, an issue with shutting down Windows with it running...an error dialog comes up. But I set XP to force-close hung apps, so it's not really an issue...
    AM 2.0 is s'pose to be coming out soon too...
    I have a shortcut with a command line to my AM setup files in the startup folder, so whenever XP boots, i'm ready for music...
    Sep 2007
    I use ASIO4All drivers for my setup...
    They work with USB sound cards too, so long as it's a supported chipset...
    Nov 2006
    Quote Originally Posted by WuNgUn View Post
    This idea sounds good. So the Rubber filter does the crossover? What is the other software that you used for chaining up the devices? I'm still trying to grasp this idea... How do you link the Stereo RCA outputs from the DAC? Cheers!
    Sep 2007
    There's no DAC outside of the soundcards...everything is handled in software.
    That image is old (and was just a test setup)...here is my current setup (with a different crossover)...
    I decided I don't need an EQ, at least not until I run a white-noise or frequency sweep test...and the LS filter has phase control as well, so I got rid of the individual phase filters.
    (Also note the sub output and VU Meter output channels)
    For doing active crossover, I decided each stereo channel (pair), instead of being left/right, or now high/low...
    Left channel is low-pass and right is high-pass.
    For a three way setup, you could add another channel, just strictly mid-bandpass, and run it as a left/right setup and pass it to the amp...
    And that's all I did...I have two Xonar sound cards...one handles drivers side (front/rear) and the other, the passenger. These output to a pair of 4-channel TRU amps...again, one for passenger side, the other for the drivers side...
    Here is the amp.
    4 X 1/8" stereo jacks (handmade) into 8 chassis-mount RCA's, and then interconnect RCA's into the amps (also handmade)
    The dual Xonar cards!
    The VU meter out is line level only, and the sub out goes to a 2 channel Alpine under the drivers seat...
    Also note, the LS filter is 3-way + sub, but it also has full-pass output on the first two channels (for the VU meters)...very nice filter!
    I could of done this with 1 soundcard (8 channels), but without sub or VU meter output. I could of spliced in for both, and let the amp do
    the sub crossover, but this gives me more flexibility and control...and the possibility of maybe 3-way in the future!
    Also, I use Virtual Audio Cable as my default playback device (in Centrafuse)...this is picked up as the audio input with Audiomulch...AM does it's thing, then outputs
    the the actual jacks on the soundcards...
    This was ONLY possible with ASIO4All drivers (else not all 16 channels were visible) and ONLY with 1731 Vista drivers (running on XP no less), or else there was 'cross-talk' between the channels, and/or the sub/center output jack wouldn't output discreetly.
    Did a LOT of testing (drivers, operating systems, etc) and hair-pulling to make this work, let me tell ya!!
  1. Small Car, budget complete setup advice
    By Scouse Monkey in forum Car Audio
    Last Post: 07-14-2010, 12:17 AM
  2. Noobie Questions, Advice needed
    By Phoenix_MR2 in forum Newbie
    Last Post: 03-09-2005, 02:36 AM
  3. How fast of a computer needed for dual monitor (GPS & DVD) setup
    By mykolJay in forum General Hardware Discussion
    Last Post: 09-23-2004, 04:29 AM
  4. Advice on a Setup (kinda long)
    By f250crewcab in forum Newbie
    Last Post: 08-20-2004, 06:06 AM
  5. Advice on Setup...
    By blackout03specv in forum Newbie
    Last Post: 06-29-2004, 10:36 PM
