Page 13 of 22 FirstFirst ... 345678910111213141516171819202122 LastLast
Results 121 to 130 of 211
Thread: Alpine AINet CRC solved
  1. #121
    Mar 2010
    Quote Originally Posted by RipplingHurst View Post
    Wow, congrats! Looks nice. What does it do exactly? Works with any Alpine unit ?
    Draft design document is available here:
    https://docs.google.com/document/edi...XxzVVRDk&hl=en
    Generally it works with any AiNet device, but you'll need to know what packets you'd like to send and watch for. Basic control functions for H700/H701 (i.e. volume, balance, fader, presets, on/off) are also implemented.
  2. #122
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Thanks, I'm reading the doc now.
  3. #123
    Dec 2009
    Dude!!!! Stokedddddddddd yet again you come to goods! Keen as hell for one :-) will PM you
  4. #124
    Jan 2011
    Dear Nik,
    Is your item used to connect CarPC with alpine monitor as well?
    Can this item enable Alpine monitor to display as computor screen and use a touch screen to control computer like mouse?
    Jokekim
  5. #125
    Mar 2010
    Quote Originally Posted by jokekim View Post
    Dear Nik,
    Jokekim
    My controller could connect CarPC to Alpine monitor via AiNet, but I don't see how it could be beneficial. AiNet is not intended for graphics transfers (it's simply too slow), so you'll have to connect graphics board of the CarPC to monitor's vieo input (which ussually looks pretty badly).
    As far as I know Alpine monitors not broadcasting tochscreen inputs to AiNet. In that case touchscreen control interception is uneasy task.
  6. #126
    Apr 2008
    What is the price and is it itegrated into any/all front ends? I do you need the RUX or can I get just the H700/701 and use it that way?
    Edit: I did read that there is no need for the RUX but I would still like to know about the front ends and price.
  7. #127
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If this unit connect between Alpine iNet unit and can control PC by the HU, I'm sold.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  8. #128
    Mar 2010
    Quote Originally Posted by MatrixPC View Post
    Please note that Alpine HUs not sending plain button presses to AiNet, it's using the AiNet for communication with known external devices like Changers, processors, etc. So you'll have to emulate some device to get the inputs from HU.
    My controller could emulate Apline CD-Changer and route all HU inputs for changer (Change disk/track, play/pause, repeat/shuffle) to PC's COM port. If your Car PC could read the inputs from COM port and above mentioned functionality is fine for you, then it could be done.
  9. #129
    Mar 2010
    Quote Originally Posted by davedave1234 View Post
    Estimated price for complete board is $150 USD without shipping. Hope I'll not be banned, as this is still non commercial project. I'll finalizing the firmare now and will publish all schematics and source code shortly.
    You will need the RUX to set up the H700/701 as I'm not going to implement every single setting like EQ, TCR and Phase. However after setup you might just store preferred settings in presets and use controller for everyday operations like volume, fader, balance, sub level, input selection, preset switching. RUX could be disconnected at that stage or you could use it simultaneously with controller .
  10. #130
    Apr 2008
    Quote Originally Posted by Nik1976 View Post
    You will need the RUX to set up the H700/701 as I'm not going to implement every single setting like EQ, TCR and Phase. .
    That's to bad because I found some 700/701's without the RUX for $250 but with the RUX they are closer to $500 plus the $150 (not a bad price by the way) makes it a little steep. O well it is the best option for audio I have seen though. Anywaylet me know when they are available so I can look into getting
    everything.
    Thanks for the info,
    Dave
  1. Alpine AiNet aux input adapter SOLUTION!!!
    By aydensdad in forum General Hardware Discussion
    Last Post: 08-16-2011, 05:30 AM
  2. headunit and screen?? also alpine type r sub?
    By st_wanabe1 in forum Car Audio
    Last Post: 10-17-2008, 03:48 PM
  3. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 05:34 AM
  4. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 07:45 AM
