Page 14 of 23 FirstFirst ... 4567891011121314151617181920212223 LastLast
Results 131 to 140 of 221
Like Tree1Likes
Thread: Alpine AINet CRC solved
  1. #131
    Mar 2010
    Quote Originally Posted by davedave1234 View Post
    That's to bad because I found some 700/701's without the RUX for $250 but with the RUX they are closer to $500 plus the $150 (not a bad price by the way) makes it a little steep. O well it is the best option for audio I have seen though. Anywaylet me know when they are available so I can look into getting
    everything.
    Thanks for the info,
    Dave
    You might borrow the RUX or H701-compatible alpine HU from someone just to setup the presets, it's not needed for everyday use.
  2. #132
    Apr 2008
    Quote Originally Posted by Nik1976 View Post
    I don't know anyone with one but maybe I can find one when he time comes.
  3. #133
    Feb 2005
    I got a bit mixed up here, but it looks like a carPC (windows based?) can control the H701 with this controller? If so, I need to save some pennies and pick one of these up. I have always wanted this ability and think it is the number one best innovation to come from this forum in a long time.
    Brent
    1999 Nissan SE-L - turbo toy
    1993 Nissan NX - Turbo Racer
    Standalone fuel management (AEM EMS) on both
    carPC
  4. #134
    May 2004
    UK
    Hi Nik,
    I've had an idea rattling around -thought I would see if it's desirable or possible.
    The typical use involves a PC to issue the RS232 commands your "wonder-box" will send on as AINET. All good!
    I cannot help think it would be useful to use some of the PIC I/O to create 2 direct control inputs: volume up / volume down. Directly controlled by the PIC with no external device needed.
    Why?
    There will be times you may be using a non-PC sound source, and it would be great to get use of the solution when the car-PC is off. The volume control button/knob in this scenario is then a control that always works.
    See - i've convinced myself! what do you think?
  5. #135
    Mar 2009
    Quote Originally Posted by Tony G View Post
    If you're going to do that, why not have all of the PIC I/O's going to a header on the PCB, and have perhaps 2/3 of them pre-programmed for volume up/down and mute. That way, to add any other buttons, would be just a matter of wiring it in and programming it up.
  6. #136
    May 2004
    UK
    Quote Originally Posted by jcerecke View Post
    Why not indeed!? Reading the design document, it looks like there could be some I/Os on a header - quoted for IR/Relays/Switches, so could be programmed for direct control of volume ...
    Nik?
  7. #137
    Mar 2010
    Nik?
    Sorry for a long silence. Personal issues kept me away from the project, really hoping to finally complete boards and publish the code this week.
    I intentionally kept 4 AtMega I/O lines (PC2-PC5) on the header for future expansion. It could be used for input (check for specified voltage below 5V or for the ground pull up) or output with small current (50mA max).
    So yes, with small firmware tweaks those I/O lines could control the volume directly.
  8. #138
    Oct 2007
    Reno, Nevada, United States
    Just got my h701 today and installed it Just gotta say my excitement for carpc`s just picked wayyyyy back up!!! Ohhh man Optical out into the processor and then to the amps it so amazingly clean, I cant wait for this PC Interface, Please dont give up
  9. #139
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by hondabldr View Post
    It does just make you smile when you listen, doesn't it?
  10. #140
    Oct 2007
    It really does!! Considering the last many years fighting with nasty pops, ground loops and everything elese that comes with a computer direct to amps
    Its to bad Mitch stopped making the xm direct optical conversion kits, with this usb control thats in the works for the alpine and a little plug in to switch between optical inputs from the front end would be perfect!!!
  1. Alpine AiNet aux input adapter SOLUTION!!!
    By aydensdad in forum General Hardware Discussion
    Last Post: 08-16-2011, 06:30 AM
  2. headunit and screen?? also alpine type r sub?
    By st_wanabe1 in forum Car Audio
    Last Post: 10-17-2008, 04:48 PM
  3. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 06:34 AM
  4. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
