Page 6 of 22 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 212
Thread: Alpine AINet CRC solved
  1. #51
    Mar 2009
    What I would love to do with an AI-net interface is select a song from a CarPC from the headunit. Have it display title/artist/time/album etc. I don't expect you to rush off and make it happen though... just what I've been wanting to do for a while.
    Congrats on everything though, really great news.
  2. #52
    Mar 2010
    Quote Originally Posted by jcerecke View Post
    Wow, project is starting to get quite complicated. HU definitely not sending song information to processor. If some external AiNet device (display?) could show songs list from HU and remotely select songs then AiNet traffic could be intercepted, analysed and re-used.
    My controller could read AiNet traffic with sending it to PC and send packets to AiNet. You'll be able to analyse packets by yourself and emulate any AiNet device you need with very little coding.
  3. #53
    Maximum Bitrate PhilG's Avatar
    Mar 2009
    Ontario, Canada
    "Other remote operations (i.e. fader, EQ, presets) could be easily added later, just let me know what else you're looking for."
    I second the need for bass level control for the sub out channel.
    Also if the input selection could be controlled by the actions of Centrafuse, that would be amazing. I have a toslink cable from my X-fi going to the processor and I am converting my MJ SC-C1 satellite box over to a toshlink to run back to the processor separately instead of through the X-fi first. So when I select "Sirius" in CF, if it could switch inputs on the H701, that would be amazing. If a BT call in CF could trigger the third input, I could possibly convert the mic over to optical as well.
    I am doing a 5.1 surround setup so if switching CF to "DVD" could trigger the processor to switch from 2.1 to 5.1, that would be an added bonus.
    Are you sorry you asked??
  4. #54
    Sep 2006
    Flanders - Belgium
    I completely agree with PhilG's requests, in addition to my own requests
  5. #55
    Mar 2010
    Quote Originally Posted by PhilG View Post
    Bass level control is already on my "to do" list
    I'm not familiar with Centrafuse, but guess it should be pretty flexible and open for different kinds of hardware. All you'll have to do is teaching Centrafuse to send specific command to COM (or USB) port when particular playback device is activated. Hope that shouldn't be an issue. Surely, I'll publish all AiNet commands I know, but you'll be able to send any other commands discovered by community.
    I don't get why you'd like to convert analogue input from mic to optical when H700/H701 equiped with three independent analogue inputs (one RCA and two AiNet accessible via simple AiNet->RCA adapter).
    As far as I know H700 automatically detects DolbyDigital and switching to 5.1.
    However if you'll set up all 5 acoustic channels + 1 sub even stereo source will be automatically distributed over 5.1
    Not yet
  6. #56
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by Nik1976 View Post
    I would expect that this can be done too, but I'm not too sharp at this stuff. I'm sure help will be available to figure it out over on the FluxMedia forums.
    Only to try to eliminate as much noise as possible. It's a long run from the front to the back with a lot of power wires along the way. I hate 3.5mm mini plugs, they seem to always end up loose & noisy. I have a $10 convertor ordered to convert the Sirius box to optical so I just thought, if I did the mic as well, all 3 optical inputs would be used and muting all other sources would be a non-issue if I was actually switching input sources when the BT phone was activated. Again , I'm not sure it would work but might be worth investigating.
    It may, I just have not had the oportunity to spend much time with the processor features yet to find out. I'm just in the middle of my install now.
    Thanks again!!
  7. #57
    May 2004
    UK
    This is great news. H701 control via a PC would make such a difference to my project. Happy to donate or pay a good price for any hardware...
    So nice to be at the stage where we can add our "shopping lists"!:
    1) Volume. Incremental and absolute both useful.
    2) Input selection - would this be input selection - +, or can it be absolute i.e. digital 1? Anologue 1?
    3) Sub level
    4) Fader/balance
    5) Presets
    Com port control would work well for myself using Girder.
    Hope things go well for your project from here!
  8. #58
    Mar 2009
    I'd be so keen for this. How can I get my hands on your controller? I love hacking round with stuff like this and making it do what I want, rather than what it was designed for. As for the device to intercept, I was just thinking an ipod? It should send all that stuff out.
  9. #59
    May 2004
    UK
    Ipod / Ipad would be an interesting alternative - my install is in a VW Campervan, so would be good for the rear area when sleeping etc.
    If an RS232 Com port is the hardware, this could be done using something like the Global Cache products such as a GC-100 or Itach IP2Serial for the device connection, and a PC, mobile device, and Ipod etc as a controller. Several Ipod/Ipad solutions for controlling the GlobalCache products out there.
    Think I'm getting carried away with all the possibilities!
  10. #60
    Mar 2010
    Quote Originally Posted by Tony G View Post
    3) Sub level
    4) Fader/balance
    5) Presets
    We finalizing board design, hope to complete first controllers in few weeks.
    We could build the controller in it's own case or make board suitable for integration in H701 case. Which way is better to you?
    I'd like to make the project available for community so hardware shouldn't be expensive and firmware code will be opened. Donations will be appreciated
    1. Done
    2. H701 inputs are selected by absolute addresses (each input having it's own unique ID). Sequential (+/-) selection could be easily implemented, but I don't think it's really valuable
    3, 4, 5 -- In the list already. I'm trying to borrow better HU to intercept appropriate packets. Hope to sort it out shortly.
    I'll keep this tread updated.
  1. Alpine AiNet aux input adapter SOLUTION!!!
    By aydensdad in forum General Hardware Discussion
    Last Post: 08-16-2011, 05:30 AM
  2. headunit and screen?? also alpine type r sub?
    By st_wanabe1 in forum Car Audio
    Last Post: 10-17-2008, 03:48 PM
  3. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 05:34 AM
  4. Replies: 85
    Last Post: 07-09-2007, 04:44 AM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 07:45 AM
