Depending on which sb card you're using, you should be ok without the line driver. Actually any should be ok. Only thing you'll gain with a line driver is a lower noise floor. You'll notice that when you crank up the master volume on your PC, there will be more white noise present, which is inaudible during loud music play anyway. This is eliminated with a line driver since the volume on the pc can be always set much lower.
LinkBack URL
About LinkBacks
