Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 58
Thread: Audio advisor suggests using PC as head unit is horrible...
  1. #11
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    I have one question.
    My Commell LS-373 have Realtek ALC888 onboard sound card. If someone compare this Realtek ALC888 Sound card with some other USB card? I will use digital out(optical) connected to processor(Audison BIT ONE)... So is in optical out any diference?
  2. #12
    Jan 2009
    Quote Originally Posted by PaulF View Post
    I would advise you to use some form of a hardware pre-amp. In my car if I plug my mp3 player directly into my amplifiers, it sounds okay, but if I plug it into my head unit and plug my head unit into my amps, it sounds much better as the head unit is tweaked to provide the best sound for a car environment.
    Correct me if I'm wrong, isn't a preamp to amp low level signals to line level? The PC is already at line level? Is a preamp really necessary?
  3. #13
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by stratosigma View Post
    Right. PC is at line level. If your sound card provides equalizer (which it ought to), you will probably be okay.
    Want to:
  4. #14
    Jan 2008
    Dartmouth, MA
    Yeah Bugbyte is right, if you have an equalizer to work with you can probably make it sound pretty good. Give it a shot without a preamp or head unit and you can always put one in at a later point. Even without tweaking, it will probably sound okay.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  5. #15
    Variable Bitrate rijndael's Avatar
    Apr 2007
    Florida
    im probably jumping in here a little late, and bugbyte is right, no preamp is needed.
    one thing i would look at to help you make an informed decision is "The Art of Bulding a Computer Transport"....google it. I know you arent into the whole audiophile thing, but it will give you an idea as to how far PC's have come compared to high-end hi-fi equipment (as well as maybe even help you decide on certain components and how to keep EMI at a minimum). EMI is electromagnetic interference if you didnt already know that....but im sure you did.
    anyways...if you are worried about the connections to your amplifier (as that sales-rep supposedly said it sounds like crap), you can just get a quality y-splitter 3.5mm jack to RCA (usually around 24 bucks for 3 feet..ill do a search for one and post it for you here...i use one from Stinger, and it definately sounds better than monster cable did) and keep it clear of all power cables/grounding cables and your VGA cable (energy bleed which causes interference in your cable).
    someone else probably responded since bug's last response, so im gonna go search for a y-splitter that you wont have to worry about...if you do end up going this route
    Trouble deciding on car speakers? Clicky Clicky
    My Myspace page (view my pics for carputer worklog...needs updated)
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
  6. #16
    Apr 2007
    Florida
    http://www.sonicelectronix.com/item_...er+SPI336.html this is very similar to the one i have...the only difference being this one is 6 feet instead of 3 and the 3.5mm jack on mine is straight, not an L. tell that rep to "shove-it"
    Subwoofer: removed
  7. #17
    Jan 2009
    Quote Originally Posted by rijndael View Post
    haha, you guys rock. Thanks a bunch!
  8. #18
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by _Dejan_ View Post
    You do realize, that the S/PDIF digital audio format COMPRESSES the signal?
    Even the TOSLINK optical interface uses compressed data.
    Some of the earlier TOSLINK equipment (not PC's) used raw PCM audio data, but almost everyone now follows the IEC 61937 S/PDIF compression format...
    With that said, a pure digital signal thru TOSLINK would be an option in the noisey car...the TOSLINK won't pick up any EMI at all.
  9. #19
    Newbie Nukeb32dc2's Avatar
    Dec 2005
    New York, NY
    If he is thinking about the compressed music medium- he's right BUT the same goes for mp3 car stereos. I am sure he is thinking about standard line-level out ran, say, 6+ feet to your car stereo.
    Whenever you are running a low level input over a distance, especially in a car- the connection is subject to mutual coupling. AC leakage from your alternator, fuel pumps, and car wiring can all contribute to unwanted noises.
    I got around this 4+ years ago easily. I used a USB based Sound Blaster card that I located to the rear of my headunit. Since the audio is purely and inarguably digital on its way to said headunit- there was no audible interference of any kind. From my USB sound blaster, I connected a hefty set of 4-5" RCA connections. Therefor, the vulnerable analog output was only subject to interference in that small portion. The end result was very pleasing...although I still wish I could have used that digital out!
    Hope this helps.
  10. #20
    Sep 2007
    What I'm saying is, whatever is coming out of the S/PDIF or TOSLINK, whether it MP3 or lossless or 24-bit DVD-A, the signal is getting compressed...it's a built-in standard of the interface, as it was designed mainly to handle multi channel, 7.1 data...
    For the short runs that we all use analog RCA's, they aren't very suseptible, especially if all the equipment is in the trunk...
    A lengthy run like head unit-to-trunk will always be an issue though...
    Personally, I still think analog is still the ideal choice...
  1. CarPC radio reception: PC tuner or head unit?
    By xraycat in forum Car Audio
    Last Post: 01-18-2007, 06:57 PM
  2. Easy head unit question, and PC to amp question.
    By dudah85 in forum General Hardware Discussion
    Last Post: 09-09-2001, 03:57 PM
