Hi guys,
About my onboard sound card which use Realtek ALC888...
Few informations about ALC 888 you can find HERE
and if I copy few data:
Code:
Hardware Features
# Hardware Features High-performance DACs with 97dB SNR (A-Weighting), ADCs with 90dB SNR (A- Weighting)
# Meets performance requirements for Microsoft WLP 3.0 Premium desktop and mobile PCs
# Ten DAC channels support 16/20/24-bit PCM format for 7.1 sound playback, plus 2 channels of independent stereo sound output (multiple streaming) through the front panel output
# Two stereo ADCs support 16/20/24-bit PCM format, one for stereo microphone, one for legacy mixer recording
# All DACs supports 44.1k/48k/96k/192kHz sample rate
# All ADCs support 44.1k/48k/96k sample rate
# 16/20/24-bit S/PDIF-OUT supports 44.1k/48k/96k/192kHz sample rate
# 16/20/24-bit S/PDIF-IN supports 44.1k/48k/96k/192kHz sample rate
# Up to four channels of microphone array input are supported for AEC/BF application
# High-quality analog differential CD input
# Supports external PCBEEP input and built-in digital BEEP generator
# Software selectable 2.5V/3.75V VREFOUT
# Two jack detection pins each designed to detect up to 4 jacks
# Supports legacy analog mixer architecture
# Wide range (–80dB ~ +42dB) volume control with 1.5dB resolution of analog to analog mixer gain
# Software selectable boost gain (+10/+20/+30dB) for analog microphone input
# All analog jacks are stereo input and output re-tasking for analog plug & play
# Built-in headphone amplifiers for each re-tasking jack
# Two GPIOs (General Purpose Input and Output) for customized applications
# Supports anti-pop mode when analog power AVDD is on and digital power is off
# Supports digital microphone interface for improved voice quality 48-pin LQFP ‘Green’ package
Software Features
# Meets Microsoft WHQL/WLP 3.0 audio requirements
# WaveRT-based audio function driver for Windows Vista
# EAX™ 1.0 & 2.0 compatible
# Direct Sound 3D™ compatible
# A3D™ compatible
# I3DL2 compatible
# HRTF 3D Positional Audio
# Emulation of 26 sound environments to enhance gaming experience
# 10-Band Software Equalizer
# Voice Cancellation and Key Shifting in Karaoke mode
# Realtek Media Player
# Enhanced Configuration Panel to improve user experience
# Microphone Acoustic Echo Cancellation (AEC), Noise Suppression (NS), and Beam Forming (BF) technology for voice application
# ALC888DD-GR features Dolby® Digital Live and DTS® CONNECT™ software (Optional)
# ALC888H-GR features Dolby® Home Theater(software feature)
What do you think now? Is good enought? I will use optical out.
