Results 1 to 4 of 4
Thread: KX DSP Confusion
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    KX DSP Confusion
    I am very confused after reading tutorials of the KX Drivers DSP configs. I am not looking to go crazy with them, however I assume some slight tweaking from the default DSP config would improve over all SQ. Mainly, I want to use the 10 band eq. I have 4 components for the F and R's of my SUV, one sub in the rear on the Sub channel, and a sub under my seat used with the Center channel. I have it set to 5.1 surround and utilizing the center channel allows seperate level control over each sub. If I want to add the 10 band EQ to my DSP where would it be placed? Anyone have any examples or files? Thanks.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    when you are in the dsp screen, there is one final block that is to the outputs (might be "epilog"). When you hover over or click the connection point it will give you a short name for that connection point. insert between that block and whatever it connects to. Keep track of it because you have to first delete the connection line.
    Nov 2007
    PA
    Quote Originally Posted by durwood View Post
    I was able to get "Timbre" in however it refuses to let me use the 10 Band EQ. When I ad the 10 Band EQ even to the screen it gives me an error stating "No more GRS available" or something like that. So it won't even enable.
    Sep 2006
    That means you need to shed the fat. Ditch the parts that are not needed. Ther eis only so much memory onboard the soudncard DSP chip.
    I wouldn't bother with adding EQ there. I don't really like EQ's personally, but the you are better off using the VST bridge in winamp and load a VST EQ.
  1. Embedded Kx Mixer?
    By ronjon228 in forum Software & Software Development
    Last Post: 03-14-2008, 02:45 AM
  2. Confusion Says
    By Enforcer in forum Off Topic
    Last Post: 01-30-2007, 02:22 PM
  3. Piping audio to DSP via S/PDIF
    By nasa in forum Car Audio
    Last Post: 10-28-2006, 08:34 AM
  4. Xenarc 7" In Dash & Audiobahn ADD51T DSP
    By Memorex in forum LCD/Display
    Last Post: 09-29-2006, 06:32 AM
  5. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
