Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Pioneer Premier DEH-P600UB with Western Digital Hard Drive
  1. #11
    Mar 2009
    Well that's a real kick in the A$$!
    Any suggestions on how to do so?
  2. #12
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Take a usb cable, splice the +5v and ground but leave the two data cables connected. Then connect those two ends to a +5v power source that can supply the required current? Never tested though...
  3. #13
    Jan 2008
    Dartmouth, MA
    The cheapest way I can think to do it is to find a cell phone/ipod/mp3 player charger for a car that is rated for 5 volts and and at least 1 amp.
    You can then cut a usb cable and set it up so that the green and white wires inside the cable go from the head unit to the hard drive and the black and red wire go from the charger to the hard drive. Red is positive, black is negative.
    If you mess it up, don't blame me.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  4. #14
    Apr 2008
    I have the exact same setup. The Pioneer deck only supports about .5 amp max. The WD HDD requires 1 amp. Here's my fix:
    http://www.mp3car.com/vbulletin/1275743-post6.html
    Works great now. Only problem I've had post-booster is that the HDD doesn't like temps <35 deg F. Sometimes on cold winter mornings, the USB will not power up until the heat has been on for a while and then the truck restarts. Other than that, starts up with the truck every time.
  5. #15
    Mar 2009
    Quote Originally Posted by PaulF View Post
    I'd like to keep it all behind the dash though. Don't really want that bulky thing in my CIG slot, or cables out in front.
    Any other thoughts?
  6. #16
    Mar 2009
    Quote Originally Posted by jayhawkclint View Post
    Great solution! Unfortunatly, I don't have the know-how to do something like that. How bout you build it and send it to me.
  7. #17
    Apr 2008
    Quote Originally Posted by BLACKTOOTHGRIN View Post
    It really wasn't hard. You need a $10 soldering iron from RS and a little bit of flux core.
