I don't have any experience with this deck, but if the deck is powering the HD then it could be that the HD is drawing too much power from the deck.
You may want to try giving the HD an external power supply. If you were to then cut the power wires inside the USB cable and have the HD's external power supply turn on and off with the head unit, that would probably solve all problems because the head unit would see the HD only get attached once it has been turned on.
LinkBack URL
About LinkBacks
