Results 1 to 4 of 4
Thread: 2 Amplifiers for 2 Channels
    Mar 2009
    Hello I have to small 25x2 Zapco amplifiers. I want to see if its a good idea to use them in bridge mode to 50w and use one for the left and the other for the right channel speakers. I will be using 6.5" componet speakers.
    Any info will help thanks.
    Constant Bitrate scatebase's Avatar
    Oct 2008
    As long as your speakers can handle the power (shouldn't be an issue), that should work.
    If the amp that your using is the z100c2, you should double check the power rating. It looks like they are rated at 100x1 @ 4ohms.
    If you had 2ohm speakers, you would only need 1 amplifier.
    Mar 2009
    Hey thanks for the reply.The Amp is an old Z50S2 that are rated at 2X25w I have two of this and they work great. I will try the setting and post the results.
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    If it were me, I'd use them to go active. (provided you have the HU capability...)
    Play with it, 'til it's broke.
  1. Number of channels on mp3 audio.
    By stonestatue in forum Car Audio
    Last Post: 08-25-2008, 06:58 PM
  2. Some Sirius Channels Missing - RR BMV2 Skin
    By dajayspot in forum Road Runner
    Last Post: 04-19-2008, 09:13 PM
  3. Don't Get Many XM Channels
    By ~*77*~ in forum Road Runner
    Last Post: 12-24-2006, 07:27 AM
  4. Strange alt whine when more than 2 channels (LONG)
    By vettejock99 in forum Car Audio
    Last Post: 02-26-2006, 11:38 AM
  5. how come high end EQ's are only 2 channels?
    By ketchup318 in forum Car Audio
    Last Post: 04-28-2005, 08:35 PM
