Results 1 to 3 of 3
Thread: need to know the best way how to wire up a kenwood kac-7203 amp 2 12" memphis dvc sub
    Mar 2009
    not to sure on how to wire them up....i have them wire up right now but i'm not sure if it's right.....so any info would be helpful thanks
    Link removed - Enforcer
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    If you are running the dual voice coil version of the sub, run both the coils paralell for a 2 ohm load, it will sound better. Your Kenwood amp is running 500W per channel(1000W max) but is probably overrated and you might be getting a little over half that (500W RMS both channels combined) Your subs could probably use a bigger amp!!! I would go with 2 class D monoblock amps 1000W each.
    Mar 2009
    thanks....i got em wired up now and workin but maybe i will go with the class D like ya said but for now it's workin and sounds good so i'm happy
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. how to wire amp turn-on lead?
    By emdzey01 in forum Power Supplies
    Last Post: 02-03-2006, 12:48 PM
  3. Replies: 2
    Last Post: 04-24-2005, 07:01 PM
  4. FS: 3-way Components, Sub, Amp, and Wire!
    By Sandstorm in forum Classified Archive
    Last Post: 12-10-2004, 01:10 PM
  5. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 02:21 PM
