Results 1 to 3 of 3
Thread: Grounding of Amp
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Grounding of Amp
    I see in lots of forums that it's best to double ground the amps..
    One to negativ on the battery, and one to ground/chassis.
    What I cannot clearify, if this is only true when the amp is at long reach from the battery.
    In my car, I have aprox 1m of cable between the amp and the battery, and have per today only grounded to the negative pole on the battery.
    Is there something to "gain" by grounding to the chassis as well?
    Jul 2006
    Brisbane, Australia
    It really is just a precaution IMO. If you have good earths, it is not required. Most car electrical faults can be traced to poor earth. Just make sure you sand the paint off to bare metal and get a good physical contact. I've done several installs various ways and have never had problems if youy take the time to do it right.
    2007 Toyota Hilux with a CarPC..
    OziExplorer GPS Embedded in RR:
    Feb 2009
    you only ground an amp to the chassis of the vehicle.this is because you want your ground to be VERY short... no more than 1.5 feet long
  1. Replies: 38
    Last Post: 11-30-2010, 05:04 AM
  2. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 08:38 PM
  3. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 05:40 PM
  4. Grounding Amp and Pc
    By Ripsurf in forum Power Supplies
    Last Post: 07-27-2004, 11:23 AM
