Originally Posted by
bes51659
You have a ground loop with the audio and the USB cable.
1) Are the analogue extension and the USB cable drawn the same way from the boot to the LCD panel?
You could have a loop sensitive to magnetic noice that is proportional to area between the two wires. If possible, twin them.
2) You could break up ground loop in audio with standard component, or use a wireless USB hub.
3) You can cut the red and the black wire in the USB cable and source the LCD panel with 5V separately from dash.
