Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
Thread: Amps????????
  1. #11
    May 2009
    will this amp work for just the two 1300 watt subs? just take a look at it....
    http://www.sonystyle.ca/commerce/ser...h=n32150n46280
  2. #12
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    OP-get a mono amp that puts out between 600-800 watts rms and you will be fine. I would recommend 1000 watts rms just for some overhead to prevent distortion from arising. Most distortion will be from under powering a speaker and over driving the amp to compensate by twisting the gain resulting in an in proper gain setting clipping the signal.
    Aron
    Absolutely 100% stock
  3. #13
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by king9899 View Post
    why do you need a 4 channel amp? and for the 5th time do not feed 1300w to your subs you might end up blowing them.
  4. #14
    May 2009
    but dont you only hook the subs up to one channel?...i was going to get a 4 channel amp in case i wanted to hook more speakers to it later to go in my doors. can that be done?
  5. #15
    Mar 2005
    Rockledge, FL
    yea just make sure the amp you're going to buy a a built in crossover, you don't want to feed highs to your subs
  6. #16
    Low Bitrate nalav's Avatar
    Apr 2009
    Louisiana
    380W RMS? That's not at all enough information. How many ohms? How many voice coils? Better yet, what is the specific model of the subs? By glancing at the amp you linked to, you would probably be under powering your subs a lot. Hard to say for sure though without the model of the subs to look up the specific information.
  7. #17
    May 2009
    these are the subs:
    http://www.canadiantire.ca/AST/brows...BSubwoofer.jsp
    i have two of them. i am planning on powering them with this amp:
  8. #18
    Jun 2007
    I would probally not go with that amp as it will underpower the subs badly. this would probally be where you want to be if you have the 2 subs in parrallel
    http://www.sonystyle.ca/commerce/ser...th=32150n46280
    this sub outputs 600W at 2 ohms so that would be 300W into each sub.
  9. #19
    May 2009
    how much would the other amp put to each of the subs?
  10. #20
    May 2009
    and what does ohm stand for?
  1. What AMPS do you recommend?
    By HiJackZX1 in forum Car Audio
    Last Post: 05-05-2009, 04:36 PM
  2. Relay Question
    By mozee in forum General Hardware Discussion
    Last Post: 04-25-2007, 11:20 PM
  3. Amps, watts, volts and ohms
    By dagnasty in forum The FAQ Emporium
    Last Post: 12-30-2005, 12:35 PM
  4. Audigy2 ZS to four amps... few questions.
    By luckydevil in forum General Hardware Discussion
    Last Post: 10-08-2005, 08:38 PM
  5. Replies: 13
    Last Post: 04-15-2005, 03:55 PM
