Those are 4ohm single voice coil subs. Wired in
parallel, it's a 2ohm load. 380w RMS for 2 subs is 760w. You should probably be looking for an amp that will do about 750-800w RMS at 2ohms into one channel (mono or bridged). Without looking too hard, I'm not seeing a Sony amp (Sony isn't so great anyway) which will produce the
power you need for those subs.
Your calculations aren't quite right Virac. 4 2ohm subs in parallel would actually be .5ohms. Without going into details about the formula, the easy way to check is by using this link:
http://www.the12volt.com/caraudio/boxcalcs.asp
