Results 1 to 4 of 4
Thread: Fuses blown, can someone tell me how I should wire this amp/sub combination?
    May 2009
    http://cgi.ebay.com/ebaymotors/2-ALP...4506.m20.l1116
    http://cgi.ebay.com/ebaymotors/ws/eB...2631&viewitem=
    I just had a shop install the amp and the subs two days ago and it sounded really good. On the way home tonight the subs just stopped working and when I got home, I found out that 2 of the 3 25w fuses blew. Maybe I can rewire it somehow so that I won't have this problem.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Take it back to the shop. installing incorrectly should be covered under warranty.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Elsewhere
    Fuses are rated in amps, not in watts.
    If the fuses are popping, then something isn't right.
    If a shop installed it, take it back to that shop to make it right.
    How about the Wiki?
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Did you buy the amp there as well?
    The amp can't draw more than aprox 1100 w at max load.
    3 x 25 = 75A
    75A * 14V = 1050 Watt
    Allso, never ever bypass fuses... you can seriously damage electronical equipment, or even start a car fire... (And most likely, the insurance will not cover it).
  1. In search of an ignition wire
    By witten in forum Power Supplies
    Last Post: 07-27-2006, 02:29 AM
  2. blown fuses
    By st_paul in forum Newbie
    Last Post: 05-16-2005, 08:34 PM
  3. Replies: 37
    Last Post: 05-17-2004, 08:01 PM
  4. Replies: 11
    Last Post: 03-09-2004, 10:59 AM
  5. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 11:58 PM
