Results 11 to 20 of 25
Thread: Touch screen w/ amp or computer to amp?
  1. #11
    Low Bitrate Jitters333's Avatar
    Apr 2009
    Quote Originally Posted by mike827 View Post
    obviously i was listing peak watts, because i didn't remember the RMS and got the sub second hand. the sub does not bump... but have you ever listened to something with NO BASS? it sucks! so i just threw that in there to even out the audio and at least have it listen-able.
    the real question i was asking, was whether or not a 4 guage wire will be able to handle all that current.
    wire stretch isn't an issue, i can always add more after the distribution block.
    EDIT: after reviewing your chart let me rephrase the question. will a 4 gauge wire which can handle X amps according to that chart which weve all seen, how many amps will that 700w sub actually pull if its only powering ****ty tinny little speakers?
    What 700w sub are you talking about, and im not sure I know what your asking? sorry
  2. #12
    Aug 2006
    sorry i meant amp
  3. #13
    Apr 2009
    you really think those things are gonna hold to a 600w peak spec? thats a pretty tall order, especially for a pair of pyramids.
    whats the RMS wattage on that? i couldn't find the info anywhere.
    No im counting on somethind around 200 rms as they are 4ways
    and my crunch amp will run a 4ohm x4 at 200rms so it should work wonderfully
    the woofers in them should sound fairly good but im hooking him up with a 12"er along with those so It should sound very nice
  4. #14
    Aug 2006
    sounds nice, you couldn't find the RMS spec either? 200rms is probably a good guess, but, for example, sony xplod 4way 6x9s rated at 300w peak only do 60w rms
  5. #15
    Apr 2009
    you mean this amp
    http://www.onlinecarstereo.com/CarAu...roductID=19342
    its 900 not 700 ampers, it will need a 8g wire at the very least I'd run a 4g personally, but a 8g should be fine
  6. #16
    Aug 2006
    I ran a 4gauge initially just to be on the safe side for the future, but will a short run (say <6") or 8gauge be ok?
  7. #17
    Apr 2009
    Do you mean these? I didn't any other 6x9s
    http://cgi.ebay.com/PAIR-SONY-XPLOD-...QQcmdZViewItem
    anyways if there under 200rms then great just watch that you don't blow them
    Edit:
    yeah totally, should be fine
    and don't forget the big three
  8. #18
    Newbie envy's Avatar
    May 2008
    Also a good rule of thumb is, add the fuses on the side of the amp up. If your current amp on your Sony sub has 3, 20 amp fuses then at max you would pull 60 amps of current on that sub amp.
    Keep that in mind if you plan on running your car pc from that 4 gauge too.
    ][ Still Building ][
    <>Intel 945GCLF
    <>160 gb WD sata 2.5"
    <>1 gb 667
    <>M2-ATX 160W
    <>ATI Radeon 7000
    <>Antec Mult-Station Premier Deluxe IR receiver and remote
    <>Windows XP Pro, and CF as front end
    <>7" LCD Myron Davis
  9. #19
    Apr 2009
    Quote Originally Posted by envy View Post
    Very true though I didn't mention this cuz that amp has a built in fuse as 90%+ of them do but yeah totally true though can never be to safe
  10. #20
    Aug 2006
    Yeah i think im pretty covered fuse wise. I have one less than 6 inches from the battery, i plan on adding one before the distribution block, and my amp has some fuses built in as well.
    also, I've seen people using low farad capacitors as a form of shutdown timer, they run the pc until they drain too low in voltage, shutting it down! (but usually giving enough time for a safe shutdown) I think I may do that...
    hopefully my 4gauge can handle all the current!
    and not only do I plan on doing the big 3 upgrade, I hope to increase my cars grounding by adding some ground wires in the engine bay.
  1. FS: Xenarc 700TSV Touch Screen Monitor
    By VYR8 in forum Classifieds
    Last Post: 01-18-2009, 12:21 AM
  2. Replies: 0
    Last Post: 10-05-2008, 01:18 PM
  3. In Dash Touch Screen with 4-ch Amp?
    By mike827 in forum LCD/Display
    Last Post: 06-29-2008, 05:34 PM
  4. Accessory Review: 3M Vikuiti Touch Screen Protector
    By AcuraTLFan in forum The Review Palace
    Last Post: 09-27-2007, 04:18 AM
  5. All In one touch screen flat screen computer for cheap
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 04-25-2001, 01:38 PM
