Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: need amp turn on delay, speakers pop
  1. #21
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    the guy told me the way the DEI 528t pluse timer relay module work is you can adjust the time you want a device to come on, he never said that it would turn back off. it should stay on as long as it has power.
    https://www.directedstore.com/cgi-bi...ategory%3DA_SE
  2. #22
    Jan 2008
    Quote Originally Posted by customaudioman View Post
    the info on this module is very minimal, but if it works like any other device w/ a remote lead, it should turn off imediately after the ignition is turned off,
    and that should take care of the 'off' pop (assuming that you have a shutdown controller that waits a couple of seconds), the startup delay should take care of the 'on' pop.
    for $30, I will probably purchasing one of these modules for myself!
    the only confusing part is the remote lead- the info says that it can take a + or - signal, but the diagrams only show a - signal.
    I can build a reverse polarity circuit if necessary, but would prefer to use a positive lead for simplicity's sake.
  3. #23
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    It's a pulse timer so it outputs a pulse (1-90 sec), but there is a NC and NO so it looks like NC would be a delayed off. It would click when it starts (opens NC side) then click again after the time ends. To work right 12V, common, trigger to IGN. That way it can't be on when IGN is on. NC to amp. Door pins are grounded, but have 12V when open so the trigger must handle 12V. There's a wire you can clip to reverse it. If that doesn't work, use another relay. Wow, complicated. That's why I have my timers in my sig. LOL
  4. #24
    Oct 2005
    are the m2-atx psu have the remote turn on deplay? If they do is the wire switch to ground or send 12v current to turn on the amps? still looking for a solution
  1. 4ch AMP powering 6 speakers?
    By Alfredbra in forum Car Audio
    Last Post: 10-30-2007, 06:44 PM
  2. Replies: 3
    Last Post: 05-30-2007, 12:45 AM
  3. Replies: 0
    Last Post: 05-31-2006, 11:19 PM
  4. Too much amp power for stock speakers?
    By black06stang in forum Car Audio
    Last Post: 04-30-2006, 09:02 AM
  5. Replies: 3
    Last Post: 04-28-2006, 11:51 AM
