Results 1 to 10 of 14
Thread: hooking up speaker to mono amp
    May 2009
    parkersburg WV
    my mono amp has 4 places to hook my speakers up(2 pos. & 2 neg.)(like a 2 channel)in the instruction booklet it shows the positive wire going from the speaker then splitting into two lines and hooking into both positive terminals in the amp, and the same with the negative side....my question is, do i need to splice my pos.&neg. wires to fill up all four terminals? or can i just run the one pos. wire into the amp and one neg.???? does anybody with a mono amp know WTF im talking about!? does the picture not mean split the wire, but that its universal and i can run the wire to either terminal as long as i got a neg&pos????
    May 2009
    parkersburg WV
    think i got it
    i had to think about this one and i think i got it...a speaker wire is actually two wires, on for pos and one for neg.....im assuming i run BOTH wires into subs pos. terminal and split the other end and run one wire into each pos. terminal in the amp and the same with the negatives... does this sound right?seems like the idea!
    May 2009
    parkersburg WV
    new question
    ok i actually got 3 dvc subs that im running series/paralell. this requires me to run a wire from 1 pos. to 1 neg. on each side...then run the positives to the amp and the negs to the amp. should i continue to use both wires, when i hook up 1 pos to 1 neg voice coil? and both wires when i hook the positives togather and run to the amp, and negs togather to run to amp? i hope this makes sence, if not tell me im retarded and ill try to explain it better!!!!!!
    Newbie Sponge's Avatar
    Apr 2009
    San Jose, CA
    Make and model of the the amp and three subs?
    This should help as well:
    http://mobile.jlaudio.com/support_pages.php?page_id=161
    If your amp truly is a mono block, then the two positive and two negative are just there for convenience. In that case, the positive share the same piece of metal and so do the negative... kind of like a y cable.
    May 2009
    parkersburg WV
    series vs paralell
    are their any pros and cons to wiring series vs parallel (other then ohms) it seems like wiring my three dvc subs parallel/parellel is better than wiring parallel/series because lower impedance, why would anyone choose parallel/parallel? is it because they dont have an amp with low enough ohms, so they wire par/ser? ya know what i mean??? im a stoner, sorry
    May 2009
    parkersburg WV
    thanks
    hey, thanks for clearing that up. helped ease my mind! THAT CHART JUST SAVED ME 1 FULL OHM OF IMPEDANCE!
    Quote Originally Posted by Sponge View Post
    Low Bitrate nalav's Avatar
    Apr 2009
    Louisiana
    What is the make and model of your subs and amp?
    As far as why go parallel or series, the exact reason is impedance. Impedance is a direct factor in how much power your amp is pumping to the subs. Too much or too little impedance and the amp could put out more (or less) power than desired, potentially blowing the subs. Also, too low of an impedance might damage the amp, or might not even be possible with the amp. Whether you wire them all parallel, all series, or a combination of both, the impedance is what matters in the end. Often times people who don't understand this buy an amp that looks like it matches the subs, but in reality will only put out 1/4 of the power they expect after they hook it up. Calculating the proper impedance and power levels will keep you safe in this area.
    May 2009
    parkersburg WV
    confused
    #1 option- if i wire my subs ser/par its 1.33 ohms
    #2 option- if i wire them par/par its .33 ohms
    my amp is 1 ohm stable
    im thinking #2 would fuk my speakers?
    is #1 the correct way to fly?
    btw i have 3 dvc 2ohm 10" 450watt rms subs
    my amp is 1200watt rms mono, 1 ohm stable
    Apr 2009
    San Jose, CA
    #1 and you're set.
    Option 2 would overheat your amp / send it into protection mode... so skip that idea.
    May 2009
    parkersburg WV
    thanks sponge, you dont even know how much i appreciate that info.... now all i gotta do is run this dang power wire through the firewall!
  1. connecting amp to speaker wires in OEM harness
    By azlunchbox in forum Car Audio
    Last Post: 03-18-2009, 03:46 PM
  2. Replies: 0
    Last Post: 02-20-2009, 10:04 PM
  3. Replies: 0
    Last Post: 07-22-2008, 02:09 AM
  4. Help..hooking up new head unit to monsoon amp
    By jstick81 in forum Car Audio
    Last Post: 04-23-2008, 06:21 PM
  5. FS: Rockford T10001bd mono block amp (1000watts RMS at 1ohm)
    By therussman2002 in forum Classified Archive
    Last Post: 07-26-2005, 10:29 AM
